Site Supporter Moto Grand Prix Favorite Bike: Well, Duh!
Posts: 3,068 Other Motorcycle: Can't afford two! Extra Motorcycle: Three would be insane
The simplest and cheapest trick for installing CRG's is to to go to the local hardware store and find some stainless fender washers of around 7/8" outside diameter. You will also need some longer bar end screws (about 1/2" or so longer) you then put a stack of the washers between the weight and the bar effectively extending the bar by the required amount. This method is cheap, easy, effective but also requires no modifcation of the bike.
For an excellent online source for the washers and screws see mcmaster.com
Mick...
