Motorcycle.com
Club Cafe Cafe Racers; the Thruxton and other custom cafe-ed rides.
Old 05-16-2008   #1 (permalink)
Favorite Bike: 2006 Black Thruxton "Roxy
Other Motorcycle: 1999 Legend
Extra Motorcycle: 1978 Suzuki GS400
Need Suspension Advice
Hey there! I'm going to be upgrading the suspension on my Thruxton (finally) and I was curious to hear everyone's opinions on what brands they like. I'm talking about fork springs as well as the rear shocks. I appreciate any advice you can give me. Thanks in advance!
FlatFourOne is offline   Reply With Quote
Old 05-16-2008   #2 (permalink)
hobbes80's Avatar
Other Motorcycle: None, ATM
With almost no actual experience, I have no place giving advice, however, I have "wasted" a lot of time reading threads on this forum...
There is good fork advice in this thread:
http://www.triumphrat.net/club-cafe/...onversion.html
hobbes80 is offline   Reply With Quote
Old 05-16-2008   #3 (permalink)
I chose Ikon forks and shocks. Upgrading fork springs should be done immediately. The benefit is immediately appreciated. The shocks give more feedback, but are compliant enough to keep the rear planted over lower quality roads. The overall ride is stiffer than stock, which isn't the goal, but is a difference.
I've not messed with adjusting the shocks much, choosing to wait for a track day where I can repeat cornering between changes. With only a few thousand miles on the upgrade, I'm very happy with the Ikon setup, but have nothing other than stock to compare to.
I'd do the same again.
05 Thruxton
whoa is offline   Reply With Quote
Old 05-16-2008   #4 (permalink)
Favorite Bike: 06 Thruxton(black)
cafecruzin's Avatar
Location: land of sweeping plains,drought n flooding rain
it really depends on how much you want to spend...but IMO the Ikon setup is a good moderately priced system that will give you a much better feel for the road.if it is a little to stiff in the front end use a lighter weight oil.
ROD
Illegitimis nil carborundum
Quot culi, tot sententiae
cafecruzin is online now   Reply With Quote
Old 05-17-2008   #5 (permalink)
Favorite Bike: 2006 Thruxton 904
robnobrakes's Avatar
Other Motorcycle: 1998 Thunderbird Sport
Extra Motorcycle: Track Day Honda VTR1000
I fitted the Ikon units to the rear and have left the forks alone other than reduce the spring preload by one ring. I have fitted the Hyde fork brace and Hyde steering damper. I weigh 175lbs without riding gear and this set up is perfect for me, on the road and track. The Ikons give a more compliant ride over the bumps with excellent damping control, which is more than can be said for the stock units.
My advice - change the rear first and adjust the spring preload on the front to match. Modify the forks only if you find it necessary.
robnobrakes is offline   Reply With Quote
Old 05-18-2008   #6 (permalink)
OKcarburetor's Avatar
I weigh the same and run the forks the same way. They work 1000x better with less preload.
I am going to do the F3 swap though, just because I have the parts. If I could just stop riding the bike and actually do it...
"I never vote for anyone. I always vote against."
W.C. Fields
OKcarburetor is offline   Reply With Quote
Old 05-18-2008   #7 (permalink)
IKONS front/rear and I'm 195lbs pre-gear. Best bang for the bucks. Agreed, you dont really need to change the fronts.
Joe Black is offline   Reply With Quote
Suspension advice backroadbonnie Twins Technical Talk 3 05-29-2007 08:45 PM
need some suspension advice rvendena Speed Triple Forum 6 03-26-2007 06:27 AM
Suspension setup advice needed dawgfan Twins Talk 4 06-11-2006 02:21 PM
1200 Daytona Suspension Advice BimotaRichTT Daytona Deliberations 3 05-17-2006 08:41 AM
Suspension advice sought cal6n Twins Talk 4 07-28-2005 09:07 AM
