Motorcycle.com
Club Cafe Cafe Racers; the Thruxton and other custom cafe-ed rides.
Old 04-28-2008   #1 (permalink)
evalu8or's Avatar
520 conversion advice needed
I have a 04 Thruxton with all the regular up-grades and mods plus a little extra. I need a new chain and want to change to a 520 conversion.
My question is has any of you done this with the twins and what is the best combination for this bike w/out throwing the speed way out. I'm running a 17T front and stock 43T rear right now and quite like it. Its fun in town and still ok on the HYW.
The closest front sprocket I can find for the 520 conversion is 16T, what should I use on the rear to keep it close to what I have now?
evalu8or is offline   Reply With Quote
Old 04-28-2008   #2 (permalink)
Favorite Bike: 06 Yellow Thruxton
rbrian_taylor's Avatar
http://www.triumphperformanceusa.com...products_id=21
No personal experience.
rbrian_taylor is offline   Reply With Quote
Old 04-29-2008   #3 (permalink)
Going down 1 tooth in the front is the equivalent to adding 2.5 teeth in the rear. So if you got a 16 tooth front sprocket if you went with a 41 or a 40 tooth rear your gearing would be close to what you currently have. The 40 would be a little taller gearing & the 41 would be a little shorter.
The only thing that I can't fix is the loose nut between the seat & the bars....
Dirtynick, Internal Combustion Technician.
My Custom Thruxton project / The Dirty Brit bike
dirtynick is offline   Reply With Quote
Old 04-29-2008   #4 (permalink)
evalu8or's Avatar
Thanks Guys, I've already left a message with Triumph Performance USA, just waiting for a reply now. I'll let you know how I make out. Thank again for the input.
Looking to buy...some advice needed gil60 Speed Triple Forum 5 02-23-2008 10:44 AM
advice needed bricktop Twins Technical Talk 11 08-09-2007 06:17 PM
Advice for disc brake conversion on '69 T100? decooney Modifications & Workshop Talk 0 07-28-2007 06:34 PM
Help !!!!! Advice needed.. tccox Twins Technical Talk 15 05-11-2007 04:48 PM
Hooligan Conversion support needed!!! dml955i Speed Triple Forum 1 01-13-2005 08:52 PM
