Club Cafe Cafe Racers; the Thruxton and other custom cafe-ed rides.
Old 04-11-2008   #1 (permalink)
bnugent's Avatar
Neutral Dummy Light
Hey guys - so after storing by bike for the winter, for some reason my neutral dummy light decided to stop working. The funny thing is, sometimes it will come up, except delayed. In other words, I'll pop it into neutral and then 2-3 seconds after it will come on, but most times it doesn't come on at all. Therefore I know it's not the actual bulb - and all of the other lights on the dash work fine.
Any ideas? Could it be a fuse?
Thanks
Good judgment comes from experience - experience comes from bad judgment.
2007 Black Thruxton/AI Removal/StainTunes/Boots/Custom Accessories/Bar-Ends ... what next?
bnugent is offline   Reply With Quote
Old 04-11-2008   #2 (permalink)
Administrator
Favorite Bike: '04 Thunderbird Sport
Wombat's Avatar
Other Motorcycle: I wish!
Not a fuse. The light and others would not work if that was the case.
Most likely the switch is sticky from being stored for a while.
It could work itself loose with use or it may need replacing.
Bob
Click to see My Photo Album
Age is of no importance, unless you are a cheese.
Wombat is online now   Reply With Quote
Old 04-11-2008   #3 (permalink)
bnugent's Avatar
Thanks Wombat - could you advise on where the neutral switch is? Is it housed within the clutch mechanism or is it exposed by the arm where I could get at it and tinker w/it.
Thanks for the help. I need to pick up one of those repair manuals describing where all this stuff is.
Old 04-11-2008   #4 (permalink)
Administrator
Wombat's Avatar
Not owning a twin, I cannot help you on that, but I am sure that someone more knowledgeable than I on 'twins' will jump in and advise you.
Bob
Old 04-11-2008   #5 (permalink)
bnugent's Avatar
Thanks - now that I think about it the switch has gotta be behind the covers - there's no real "neutral" position on the actual shifter ... it's gotta be back there making it a little more invasive. I'll drop my the dealer and ask what's up.
Thanks
Old 04-13-2008   #6 (permalink)
MAR
Favorite Bike: Thruxton
Other Motorcycle: Ducati 916
Extra Motorcycle: Aprilia Falco
The wire for the neutral light indicator is on the right side of the motor next to the oil filter.Llook under the motor right belor the counter sprocket. The wire might have come loose.
"What are you rebelling against?"
"What have you got?"
MAR is offline   Reply With Quote
neutral light Zansongs Twins Technical Talk 4 10-01-2007 02:15 PM
No neutral light FlyingScot Twins Technical Talk 1 03-20-2007 11:25 AM
Neutral light went out, then.... Riven Twins Technical Talk 10 10-03-2006 03:43 PM
No Neutral Light rdm1 Tiger Workshop 2 10-27-2005 02:20 PM
Neutral Light Windchill Daytona Deliberations 0 09-29-2004 12:25 PM
