BikeBanditMotorcycle.comAdvanstarMotorcycleShowsTrident-Exhausts.com
Club Cafe Cafe Racers; the Thruxton and other custom cafe-ed rides.
Old 04-04-2008   #1 (permalink)
AI Removal on Used Thruxton
I bought my 2004 Thruxton used. As is typical for a Hinckley Triumph, the pipes were already blue. Based on experience with my Thunderbird, Blue Job will tone it down but not entirely remove it (usually shrinks the spread down the pipe and turns the color more golden than blue). Seeing how the pipes are already blue, is there any reason I should remove the AI?
Scott Irwin
Memphis, TN
"Little in the middle, but she's got much back..."
sdirwin is offline   Reply With Quote
Old 04-04-2008   #2 (permalink)
MAR
Favorite Bike: Thruxton
Other Motorcycle: Ducati 916
Extra Motorcycle: Aprilia Falco
Removing the AI, air box removal and air filters result in performance gains. This has been pretty well documented here. How much the actual gains are, might be a subject of discussion.
The blueing is a good thing. You should leave it alone and just be proud that your bike has it.
"What are you rebelling against?"
"What have you got?"
MAR is offline   Reply With Quote
Old 04-04-2008   #3 (permalink)
While I understand the performance gains from air box removal and high filters (frees up the carbs), most of the posts I've read here suggest AI removal simply lowers the temp of the exhaust. The only real benefit I've seen reported is lessening the bluing by reducing the heat through the pipes. I own 4 Hinckley Triumphs (and 3 Meriden Triumphs), so I know all about blue pipes. I just don't want to take the time and minor expense removing the AI if it's not going to do anything for me. I'm interested in comments from others on the benefits of AI removal (beyond reducing bluing). Thanks!
Scott Irwin
Memphis, TN
Old 04-06-2008   #4 (permalink)
Favorite Bike: 1050 Tiger, right?
Other Motorcycle: 01 VFR
Extra Motorcycle: 04 Sprint RS
The weight savings will make it faster offroad and lower the cg?
Sorry, just in one of those moods.
I think after the blueing occurs, there not alot of evidence that the labor is worth it. Certainly a less cluttered look.
KTMMike is offline   Reply With Quote
Thruxton bar removal.... ignition Club Cafe 2 04-04-2008 10:03 PM
Thruxton Airbox Removal K & N Filters & Rejet DYNO RESULTS robnobrakes Club Cafe 26 03-29-2007 12:51 AM
Thruxton Jetting with BC predetors and air box removal kit listo Twins Technical Talk 23 11-17-2006 11:35 PM
New Thruxton Rear Fender Removal Kit rabbid Club Cafe 2 11-07-2006 05:54 PM
Thruxton baffle removal Motoleo Twins Technical Talk 0 10-12-2006 03:05 AM
