Club Cafe Cafe Racers; the Thruxton and other custom cafe-ed rides.
Old 04-04-2008   #1 (permalink)
Thruxton bar removal....
Is the easiest way to remove the clip on bars to drop the forks a bit in the clamps and just slide them out? Seems that way, but let me know either way...... looks like i need to remove a bit of material to get my new throttle working!
ignition is offline   Reply With Quote
Old 04-04-2008   #2 (permalink)
Mancha's Avatar
The easiest way is to use an pneumatic grinding tool to cut a chunk out of both forks, simply slip out the clipons, then weld the forks back together. If you want to do it the hard way by slipping the forks down, well, that's up to you.
If you choose the latter option, you'll probably have to take off the brake caliper, the wheel, and maybe even the fender. I tried to lower both of my forks together and was, for some reason, completely unable to. (Or maybe I was able to lower them as a unit but then couldn't raise them again?)
Ogle my bike here.
Mancha is offline   Reply With Quote
Old 04-04-2008   #3 (permalink)
Favorite Bike: 08 Thruxton
Other Motorcycle: Late 60's to 70's Triumph
Extra Motorcycle: Suzuki DS-185
Call me stupied or confused but I wouldnt cut off nadda on my forks! I belive the best way to do this is the hard way.
scooterhooligan is offline   Reply With Quote
bar end removal Crogers Speed Triple Forum 13 07-16-2008 10:40 AM
1050 Bar Weight Removal turbotom Speed Triple Forum 9 10-19-2007 02:01 AM
bar end weight removal? beemmer Twins Talk 1 04-29-2006 12:28 PM
Help - Sissy Bar Removal ohiorider Twins Talk 6 03-15-2006 08:18 PM
bar end removal 04SpdTrpSE Speed Triple Forum 4 04-11-2004 07:43 PM
