Club Cafe Cafe Racers; the Thruxton and other custom cafe-ed rides.
BikeBandit
Old 04-03-2008   #1 (permalink)
Favorite Bike: 2007 Thruxton
sbpark's Avatar
billet intake question...
in about a month or so i am going to take the plunge and start doing performance upgrades on my thruxton. right now it is totally stock except for the bar end mirrors. what i am going to do is remove the airbox, air intake, throw on some predators and rejet. i was also thinking about putting on larger intakes but was curious if anyone else has done this and if there was any noticable gains?
any feedback is greatly appreciated! thanks!
sbpark is offline   Reply With Quote
Old 04-03-2008   #2 (permalink)
Retired Legend
sweatmachine's Avatar
the billet intakes are not worth it. You will see very little to NO gains with them. Save your money for other mods.
Old 04-03-2008   #3 (permalink)
sbpark's Avatar
right on. that saves me a ton of money. will probably spend that money on a fork brace or damper instead. thanks!
Old 04-03-2008   #4 (permalink)
Senior Member - Site Sponsor
JCMoTo's Avatar
I switched back to the stock intakes after installing the Billet ones.
Liked it better... for now
I would invest in a fork brace before the damper. Amazing change
and, had to remove my damper because I put a full fairing on my Thruxton
and the NH damper hit the fairing bracket and the fairing.
i really did not feel a difference in ride quality.
I will eventually install the damper again but I need to modify the damper bracket.
Good luck with your project
JC
JCMoTo is offline   Reply With Quote
Old 04-03-2008   #5 (permalink)
Favorite Bike: 06 Thruxton
roxythruxton's Avatar
Other Motorcycle: 76 CB750 86 Yammie SRX-6
I have them along with the 35mm CRs . Your bike will definitely breathe better .
Long Live The Limey:D
BIR#220
Yep. I've got some mods .
roxythruxton is offline   Reply With Quote
Old 04-04-2008   #6 (permalink)
Different Opinion
Well aint that a kick, After reading of a bunch of guys spending hours with a dremel cleaning up the stock intakes to match them to the port & remove the restrictions caused be the phenolic spacers (on the Thruxton & newer 865 Bonnies) I decided to save myself some work (bad wrist) and bought Billet Intakes. Took a bit to fit them as I wanted to retain the spacers, but now that it's done, there is a noticeable improvement.
Now - we're not talking spin up the rear or wheelie popping difference, but it does pull harder all through the rev range & it starts to pull earlier.
So while a couple hundred bucks may be alot for a little improvement, I do believe there is something there to be had! Now add the FCR or Mikuni Flatslides and hold on, I've ridden a Thrux with the FCR and Staintunes & that was a very Noticeable difference
Cheers y'all, Cyn-
First you take the test,
then you learn the lesson!
Members Album
CYNCRZR is offline   Reply With Quote
Old 04-05-2008   #7 (permalink)
Favorite Bike: 03 T100 989
mikeinva's Avatar
the only thing they do is hold carbs better they wont give you a thing other then that.Dont buy the black ones they turn color purple.I have a set i should sell cheap took them off.
Old 04-05-2008   #8 (permalink)
OKcarburetor's Avatar
how much is cheap? I'd like a set for cheap.
"I never vote for anyone. I always vote against."
W.C. Fields
OKcarburetor is offline   Reply With Quote
Old 04-05-2008   #9 (permalink)
mikeinva's Avatar
what they sell for now 1/2 price?
TPUSA Billet Intake Manifolds keanhi Twins Talk 12 03-05-2008 12:33 PM
Billet Intake Manifolds grayghost Twins Technical Talk 16 11-07-2007 09:14 PM
Billet Intake Manifolds - Worth It? grayghost Twins Technical Talk 13 04-09-2007 04:21 PM
Airbox elimination VS Billet Intake VS Ignition Box, which to get for Thrux? OldSkoolFool Club Cafe 9 10-19-2006 01:29 AM
British Customs Billet Intake Manifolds Surferjo Club Cafe 5 05-14-2005 01:29 AM
