First thing to do, check the starter circuit wiring for damage (worn insulation, broken connectors/switches).
I don't have a wiring diagram handy, but there should be a connector for the starter switch circuit, disconnect it, then turn the ignition on.
If the starter runs with the starter switch disconnected, your problem is more than likely with the starter relay (if a motorcycle starter is anything like a car's, the solenoid is part of the starter).
If, on the other hand, the starter doesn't run, your problem is with the starter switch.
"Mankind has the uncanny ability to adapt, yet still suck at everything." - Me (as far as I'm concerned)
Reason: Lengthy.
