Do the oil and filter change, and me - I'd check for loose or broken spokes, check the air box (if it still has one) for oil accumulation from the crankcase breather, clean, lube and adjust the chain, check the brake pads for abnormal wear, since the bike is used if its been 2 years since the production date then I'd bleed out the brakes good and get fresh fluid in there. Give the nuts and bolts a check up with a torque wrench. Check, clean or change the air filter(s) depending on what you have. Check tires and pressure ( I check pressure before every ride). I'm probably missing something but this will get you started.
John W.
