Club Cafe Cafe Racers; the Thruxton and other custom cafe-ed rides.
Old 10-17-2007   #1 (permalink)
S4L
Favorite Bike: Thruxton 900
Power gains
I've googled and can't find squat so..
I've got about 1300 miles now on my Thruxton and I wish it had a little more punch so I was looking at modding. So I've heard from you guys that letting the bike breathe aka airbox removal, pipes etc. opens the bike up, but can you put some numbers to that?
The only thing I can find says the thrux can run a 13.2 1/4 mile stock, what kinda numbers, acceleration wise, can you expect after removing the airbox, rejetting, and pipes??
A sidenote: My dad just got a 1200 sportster and after feeling that things torque, well, as Borat would put it, Very Nice.
Thanks for any replies,
S4L is offline   Reply With Quote
Old 10-17-2007   #2 (permalink)
Favorite Bike: '06 Triumph Thruxton
sroberts152's Avatar
Other Motorcycle: There are other bikes?
You and I are in the same boat (you have about 200 more miles on your bike than I do). I couldnt find any hard actual numbers so I did it anyway. Basically you are adding 6-10 horse for the airbox removal, upgraded pipes and AI removal and new jets. You also drop a few pounds when you get this stuff off your bike. You can do it yourself fairly cheaply (there are threads all over here for this) or you can pick up some kits and do it.
I feel the difference. I can't tell you what my gain is, but just 50 miles in without all that crap holding me back is completely worth it.
I'm not done yet, but I'm done enough until the bad weather starts.
Just listen to this:
"Those who believe in telekinetics, raise my hand."
- Kurt Vonnegut
sroberts152 is offline   Reply With Quote
Old 10-18-2007   #3 (permalink)
Yes you can expect about 10 RWHP gain or 16-18% with ARK, good free flow exhaust, and correct jetting. Some have claimed more but this seems to be a good average from all the dyno runs posted and my own personal experience at the dyno runs on bikes at the local dealership.
http://www.triumphrat.net/memberalbums/data/500/thumbs/dragon1.jpg
John W.
  • 04 Thruxton – Graphite & Opal
  • 06 T100 – Black & Red
  • 05 T100 - Black & Opal - Project Bike
  • 51 T100 – Silver & Black
Thrux-ton-up is offline   Reply With Quote
Old 10-18-2007   #4 (permalink)
Favorite Bike: 06 Thruxton
roxythruxton's Avatar
Other Motorcycle: 76 CB750 86 Yammie SRX-6
I did the TORs , wrapped the pipes , A Bellmouth and K&N , 127.5 rejet and got about a 7-8 hp gain . And went from 125 miles to reserve to about 90 . From that I went down to a 125 rejet and maybe lost a 1/2 to 1 hp but gained torque and from 90 miles to 110-115 miles till reserve.
I've heard the airbox removal would give me 2 more hp but would have worse fuel economy . I guess I thought it wouldn't be worth the 2 hp gain if I'm stopping for gas every 2 hours when I ride .
Long Live The Limey:D
BIR#220
Yep. I've got some mods .
roxythruxton is offline   Reply With Quote
Old 10-18-2007   #5 (permalink)
<---- airbox elim, exhaust, rejetted and gets 120-125mi til reserve and all the time twistin the pi$$ out of it for every mile.
Bonafide is offline   Reply With Quote
Old 10-18-2007   #6 (permalink)
If you like the low and midrange torque of the sporty, here's what I did.
I drilled six 3/8" holes down through the end of the muffler and the inner plate, about 3 inches in. I picked out the fiberglass packing.....free. I fitted the Dynojet kit....85 bucks. I added the Pingel fuel valve, but that was to cure a mechanical problem....85 bucks. I removed the AI system, plugged the holes in the air box, and cut off the tube on the injector and plugged the threaded part, and reinstalled it....free.
Bike will now idle at ridiculous low rpms, if I want. Transitions dead smooth from idle. Sounds mellow, but low. Has a lot more torque and a bit more top end. Fuel economy got slightly better. For the price, its a deal. Makes a good "first step" to get a good baseline on future mods.
Mecchanica is offline   Reply With Quote
Old 10-18-2007   #7 (permalink)
Do It Do It So It
With tips from the pros here I just finished my air box removal and it was RIDICULOUSLY worth it. I bought a $10 stock airbox off od eBay, K&N's for $70, an $8 breather tube filter, $8 in jets from a local dealer, sockets for the rear axle, and a borrowed torque wrench and it's a completely different bike. I'm now at 42 pilots, 142.5 mains, one shim, and 2.5 turns out -- the bike SCREAMS, is wicked torquey through the midrange, and I haven't noticed any significant change in fuel economy. Nothing put positives all around.
I only have butt dyno numbers measured in duration of post-ride smile, I think I'm at 72 hours of smiles over 100 miles of riding. The only thing I'm fiddling with is the main, I'm ONLY 98% satisfied at WOT, but I'll tinker with that on a ride-by-ride basis through the fall I'm sure. Changing jets at this point is easier than finding and putting on clean socks.
_____
'06 Thruxton, black, AI removed, TORs, hacksawed battery box and K&N's, 42/142.5's, one shim, 2.0 turns out, tri-bar headlamp with Hella yellow bulb, bad attitude
Monkey1 is offline   Reply With Quote
Old 10-19-2007   #8 (permalink)
S4L
Thanks
Thanks for the replies,
I like those D&D's, but I think I like the preds better, hard to tell without actually hearing them in person
I think that's what I'll end up doin is letting the bike breathe, speaking of which, anybody know what happened to britishcustoms package deal with everything together for a discounted price?
Clif
K&N Cone filters gains? REVOLT Twins Technical Talk 2 05-19-2007 11:45 PM
What are the gains with TORs or TOGAS? TTBONNE Twins Technical Talk 2 06-27-2006 09:43 PM
Performance gains? kan4132 Twins Talk 12 08-05-2005 05:56 PM
Performace gains with different pipes? Club Cafe 6 02-24-2005 12:46 PM
Tiger performance gains . . . paulie Tiger Chat 2 02-11-2004 06:37 PM
