Club Cafe Cafe Racers; the Thruxton and other custom cafe-ed rides.
Old 12-21-2004   #1 (permalink)
Favorite Bike: 04 Thunderbird Sport
vonbonds's Avatar
Way back when people were wondering if the Thruxton front brakes could be put on a Thunderbird. Has anyone looked at that more closely and if so is there a swap opportunity there?
Tom
vonbonds is offline   Reply With Quote
Old 12-22-2004   #2 (permalink)
Seems like a whole lot of expense for not much improvement over stock brakes and ss lines.
2000 TBS Cafe Racer :: 2000 Frankenmille
TBSstunta is offline   Reply With Quote
Old 12-22-2004   #3 (permalink)
Cafe Racin' Moderator
Favorite Bike: 1996 Thunderbird - Nessie
cafetbird's Avatar
Other Motorcycle: 1973 Triumph TR7RV
Extra Motorcycle: 1968 Bridgestone 350 GTR
Floating rotors, right? It looks like 320 mm - so the disc would fit on a standard Bird - not sure aboot the caliper. It wouldn't fit to a standard Bonnie - so the front forks have to be changed up a bit.
Floaters are nice - I think EBC makes them that would fit up to the Bird for about $135. Whay not just go that route?
Scot Dail, IBA #31553
Pack Member, Charlotte RAT
cafetbird is online now   Reply With Quote
Old 12-22-2004   #4 (permalink)
Favorite Bike: Well, Duh!
MickMaguire's Avatar
From what I could find out (just as the Thruxton came out) the caliper is the same unit as the Tbird and the rotor couls be swapped onto the Bird. However it is likely you would gain very little improvement (it's still a stainless rotor) all you would get is lack of coning - which I doubt that you would see on a TBird anyhow.
IIRC Scot the EBC units for the TBird were not floating, or at least they weren't when I looked, has this changed?
Mecatwin do a floating rotor for the TBird that I think is cast, this may be a better route.
Mick...
Old 12-22-2004   #5 (permalink)
cafetbird's Avatar
One of the sites that I was looking at recently listed a floating EBC rotor for the Bird - but it could have been a typo.
The Thruxton rotors I have seen are definitely floating - just look at the pics. These would give you a little better braking response.
Old 12-22-2004   #6 (permalink)
Yes the Thruxton rotors are floating, but made of the same material as the TBird's solid rotors. I was saying that the only way I could see them performing better woudl be if you were experiencing coning (what floating rotors were designed to combat). I'm not sure that the calipers on the TBird would be strong enough to generate that kind of heat/friction, but I may be wrong.
However, Beringer and Mecatwin offer cast floaters which (like the EBC units - if they exist) will provide much better braking than the stainless.
Mick...
Old 12-24-2004   #7 (permalink)
cafetbird's Avatar
Hmmm.... "coning" occurs as the front end flexes and the braking system refuses to flex accordingly, thus wearing the top of the rotor faster than the bottom, correct?
Floating rotors allow more flex, and therefore more continuous, balanced and steady friction on the rotors. I may be wrong, but my understanding is that this results is more effective braking... allowing later braking and better setting up for cornering. For this reason, I think that the addtion of floating rotors would result in better braking on a T-Bird.... but probably not as good as a 4 or 6 pot caliper addition. That might be a better use of your money!
Old 12-24-2004   #8 (permalink)
cafetbird's Avatar
Old 12-24-2004   #9 (permalink)
vonbonds's Avatar
How much would a 4 or 6 pot caliper cost? Is Jack Lilley the only source for brake upgrades like that?
Old 12-24-2004   #10 (permalink)
vonbonds's Avatar
Need to revive my Tbird brakes Wordguy Hinckley Classic Triples 13 01-29-2008 08:44 AM
Shaking front end when applying front brakes. stealthy1 Daytona Deliberations 10 11-23-2006 04:34 PM
Front Brakes, again! b50bsa Sprint Forum 31 06-11-2006 03:08 AM
Front Brakes Fatbob Tiger Workshop 3 09-22-2005 01:14 AM
Thruxton Mufflers on a Tbird? Tbird95 Hinckley Classic Triples 4 05-16-2005 09:43 PM
