» Links |
| Club Cafe Cafe Racers; the Thruxton and other custom cafe-ed rides. |
12-24-2004
#11 (permalink)
Not sure who else sells them, but just spend some time googling for distributors.
2000 TBS Cafe Racer :: 2000 Frankenmille
#12 (permalink)
12-27-2004
#13 (permalink)
Site Supporter Moto Grand Prix Favorite Bike: Well, Duh!
Posts: 3,037 Other Motorcycle: Can't afford two! Extra Motorcycle: Three would be insane
On 2004-12-24 14:56, cafetbird wrote:
Hmmm.... "coning" occurs as the front end flexes and the braking system refuses to flex accordingly, thus wearing the top of the rotor faster than the bottom, correct?
"Coning" (or "belling") is when the rotor gets so hot under braking that it becomes "cone shaped" (as opposed to it's normal flat state). This is caused by the braking surface expanding under the heat while the rotor center stays cold. This in turn stops the pads sitting flat on the rotor, and so results in fade. Floating rotors allow the braking surface to expand in a uniform manner and so stay flat because the manner of attachment provides movement between the carrier and the braking surface. You are right in that coning will produce uneven rotor wear, it can also lead to permanent warpage and cracking.
Mick...
12-27-2004
#14 (permalink)
Mick...
12-28-2004
#15 (permalink)
Site Supporter SuperBike Favorite Bike: 04 Thunderbird Sport
I guess I didn't phrase my question clearly. Are there any other options for upgrading our Tbird brakes other than the 4 and 6 pot caliper brakes on Jack Lilley such as brakes from a Honda whatever or a Yamaha doohickey? I would like to upgrade my brakes but not looking to drop $1K into it
12-28-2004
#16 (permalink)
I did find out that Brembo do a brake upgrade for the TBird but I was unable to find a supplier/price in the US - it is likely to be over $1k though.
I haven't found any cheap ways yet vonbonds. The only other options I have seen are harrison 6 pots or doing as Scot has done and swapping the entire front end for the from a TBS (can you say "hen's teeth?")
[ This message was edited by: MickMaguire on 2004-12-29 09:28 ]
Mick...
12-29-2004
#17 (permalink)
Cafe Racin' Moderator
Site Supporter SuperBike Favorite Bike: 1996 Triumph Thunderbird
Posts: 1,596 Other Motorcycle: 2002 Triumph Sprint ST Extra Motorcycle: 1973 Triumph TR7RV
....and if weight is an issue for you, that front end swap might not be the best way to go.... all that extra junk is heavy! I would say the Berringer and the 6 pots options are worth considering.
12-29-2004
#18 (permalink)
Not necessarily, I sincerely doubt that it is some special calliper, more likely one of their regular callipers and some bracket. I bet you can land that caliper pretty cheap on ebay.
12-29-2004
#19 (permalink)
It is a standard caliper and adapter bracket - the kicker is that you can only buy it as a kit which includes caliper and a new floating rotor. They will not sell the bracket seperately, nor do they list the part numbers of the rotor or caliper etc. seperately - or so I have been told.
Mick...
