Ohlins front fork completed. - Triumph Forum: Triumph Rat Motorcycle Forums
Club Cafe' Cafe Racers; the Thruxton, Bobber and other custom cafe styled bikes.
post #1 of 43 (permalink) Old 07-24-2007, 05:06 PM Thread Starter
JG
Main Motorcycle: 2005 Thruxton
JG's Avatar
Other Motorcycle: 1984 Honda XR350R
I finally finished the installation of my Ohlins fork a few weeks ago. I had posted a few pictures of the bike in another thread over a month ago when it was not quite done yet. Before the website switchover, I had almost finished an album full of photos of different aftermarket parts and many parts I made for this front end. Those old pictures are still floating in cyberspace, but are not as accessible as they used to be, so I am building a new album, which I will add more pictures to later. Click here to check it out, if you like.
I finished making a front rotor spacer, finally got the front brake rotor and speedometer sensor installed, and was able to take the bike up to top speed. Everything feels good at all speeds, and there seem to be no handling quirks. I have put about 700-800 miles on the bike since finishing the project. One minor drawback: with both the instruments and mirrors so low, when looking straight ahead, all I can see is the very top of the headlight. I have to look down slightly to bring mirrors or speedometers into view. Even when attempting to view them with peripheral vision, they are blocked by the front portion of my full face helmet. Each speedometer unit can independently display speed, trip, riding time, RPM, or odometer. The wheel circumference can be set to within 1 mm, so after calibrating at 90 mph using a GPS on a nice straight stretch of road, my speed is now displayed very accurately. I decided to keep the stock warning lights and put holes in the top clamp to accommodate them, but I replaced the stock bulbs with white 6-LED bulbs. I used the same rather large fork offset that the stock triple clamps had, which kept the steering geometry the same as stock and gave more room to fit the instruments into the top clamp. The top clamp is also a complete self-contained instrument panel. The wiring is contained below the top clamp by an attached wiring compartment I machined from a block of solid ABS. Disconnecting one connector in the headlight shell and two quick-release Lemo connectors for the speedometer sensor and the control switches will free the whole top clamp assembly. The top surface of the upper triple clamp is about 1/2 inch lower than on the stock setup. I built a downward step into the top clamp to compensate for the slightly shorter-than-stock Ohlins fork legs, and to additionally provide extra room to lower the fork legs when I eventually put a 17" wheel on the front. The handlebars ended up somewhere around 2" lower than on the stock setup, due to both the design of the top clamp and the fact that the new clip-on bars have no rise built into them. I have the bars angled down 8°, which is as low as they go. The center of the front wheel has been slightly bored out to fit a larger bearing spacer. The stock bearings have been replaced with 22mm bearings. The front wheel now rides on a 22mm RC51 front axle. The stock wheel spacers and speedometer drive have been replaced with aluminum spacers. I designed all the spacers to fit the stock dust seals on the front wheel. I made some fork guards from ABS to keep rocks and bugs off of the inner fork tubes. Overall, I made about 27 individual parts for this conversion, and modified several more. The most labor-intensive pieces were the triple clamps, which took me almost 40 hours each to make (I took my time to avoid mistakes).
Here is the fork on the bike:
Here are the upper and lower triple clamps:
JG is offline
post #2 of 43 (permalink) Old 07-24-2007, 06:10 PM
Main Motorcycle: 2005 Triumph Thruxton
tham's Avatar
Other Motorcycle: 1971 Triumph Tiger TR6
Extra Motorcycle: 80 Lambretta Jet200/1977
Thumbs up
Nice work JG!
Did you do all this on a manual mill?
Detail like that makes me wish I had an NC......
I just got a brand new digital for my Bridgeport J head, so maybe that will get me fired up for some projects.
Absolutely creative & VERY personalized.
I f-ing dig it.
1971 Triumph Tiger TR6 650,1980 Lambretta Jet 200
1977 Custom Vespa Sprint w 200 motor
1985 Vespa T5
2001 Vespa PX150
tham is offline
post #3 of 43 (permalink) Old 07-24-2007, 06:34 PM Thread Starter
JG
JG's Avatar
Originally Posted by tham View Post
Nice work JG!
I f-ing dig it.
Thanks Tham. Yes, it is all done on a manual mill. It does have a digital readout (it belongs to my company). When I remember back to before we had the digital readout on that old mill, I shudder. Counting backlash on the hand dials, even carefully, would never come close to the accuracy the digital readout can get, and you were constantly doing math in your head. And if you miscounted turns, you might drill a hole off by .200 inch. I really wish I had access to a CNC. Right now, as far as milling curved shapes are concerned, I am limited to what can be done with a rotary table. Not to mention the huge amount of time I would save having a computer cut the stuff out for me. Actually, I really enjoy turning the cranks on the manual mill. But for this project, it became a little too much of good thing, and I found myself in the shop all the time this spring, sometimes when I really didn't feel like it, just so I could get the bike on the road for summer. I had underestimated the amount of work and started buckling down too late into the winter. I missed riding the whole month of May and some of June. Now that the bike can be ridden, I am taking my time on a new project - adapting some aluminum aftermarket rearsets that were made for a Suzuki. Here is a picture of the lower clamp about halfway though the work:
JG is offline
post #4 of 43 (permalink) Old 07-24-2007, 07:09 PM
Main Motorcycle: '06 Thrux
SHRuuM's Avatar
Other Motorcycle: '08 Yamaha FJR1300A
GOOD LORD what sweet setup. Your bike looks like a bad dog with the ears laid back ready to jump up and tear someone's face off. Jealous, oh so jealous!
Mods:Predators/fork stabilizer/CR-S carbs/RaceTech springs/Berringer 6 pot caliper/Traxxion emulators/LSL sliders/Wave rotors/Pazzo Levers/Ohlins 36PL shocks/F.E.K./port&polished head/street cams/TABII Tank,seat pan/IBA #38625 SS1000,BB1500 in Texas
SHRuuM is offline
post #5 of 43 (permalink) Old 07-24-2007, 07:51 PM
Administrator
Legend
Main Motorcycle: Tiger 955i
Haggis's Avatar
Other Motorcycle: Sprint RS
Extra Motorcycle: Honda XL250
I can only dream...
I can only dream of having such skills - awesome job and beautiful bike.
I have to rely on other peoples' aftermarket parts
Haggis is offline
post #6 of 43 (permalink) Old 07-24-2007, 07:54 PM
Main Motorcycle: 13 Speed Triple R
OKcarburetor's Avatar
Other Motorcycle: 99 Sprint ST
Looks pretty amazing. Nice work on the clamps. They look really good.
Have any close ups of the gauges and idiot lights?
OKcarburetor is offline
post #7 of 43 (permalink) Old 07-24-2007, 07:56 PM
Main Motorcycle: 07 T100
Other Motorcycle: 04 powerstroke
Send a message via AIM to Ski_rat
Awsome work I love it, what would you say was the total cost?
Ski_rat is offline
post #8 of 43 (permalink) Old 07-24-2007, 07:59 PM
Main Motorcycle: None don't ride anymore
That looks AWESOME,J.
rodburner is offline
post #9 of 43 (permalink) Old 07-24-2007, 08:03 PM
tham's Avatar
Fecking -A.....
That is alot of work you did then.
The finish is awesome BTW.
lots of prep & setups for a piece like that....very impressive.
(I assumed you did it on manual because of the shape "economizing" I guess would be a good term......These pieces are all business no B u l l s h i t.)
My old heidenhain digital took a big dump a couple of weeks ago ...it was the first time I had actually used the dials on my Bridgeport for over 15 years...pretty fun.....buuuuut.....Ive already picked up a brand new Accu Rite DRO for $800..
I get too sick of milling parts for my products......that I hardly want to touch the mill or lathe after work.
Your gas cap was the one of the things that made me decide to knock out a couple of things here and there for my bike.
(I do little things here & there for my scooter restorations & for my friends on occasion.)
I love seeing things like this.
Once again...bravo!
1985 Vespa T5
2001 Vespa PX150
tham is offline
post #10 of 43 (permalink) Old 07-24-2007, 08:13 PM
Main Motorcycle: Thrux
Surferjo's Avatar
My god that gauge setup is unnecessarily cool!!!
I shudder to ask you what kind of time you have invested in it.
TRIUMPH-Turn an Ordinary Man into a Mechanic
Fun in Prague
Surferjo is offline
00 RS Front fork leaking ckassen Maintenance & Workshop Talk 8 07-18-2007 10:19 AM
Front Fork Springs wills Sprint Forum 25 11-22-2006 06:23 AM
Ohlins fork revalve kit? zmann Speed Triple Forum 0 11-01-2006 11:14 PM
Ohlins R&T Front Fork Help SIN138 Speed Triple Forum 2 07-13-2006 04:20 PM
Front fork adjustments for a '05 S3 drmuela Speed Triple Forum 1 05-27-2005 07:05 AM
