Club Cafe Cafe Racers; the Thruxton and other custom cafe-ed rides.
Old 06-28-2007   #1 (permalink)
Hi All,
This has probably been asked many times before.
I am just about to take delivery of a NARK, so I know I will need to rejet but what size of jets will I need?
So, if any of you out there are running the same set up, it would be great to hear what your carbaration set up is.
Thruxton 2006 with TOR's
Standard carb set up.
Cheers
TinTin is offline   Reply With Quote
Old 06-28-2007   #2 (permalink)
Retired Legend
sweatmachine's Avatar
you could try 42 pilots, mixture screws 1 turn out, stock needles w/ 1 shim, and start around 140 mains.
that should get you pretty close.
Old 06-30-2007   #3 (permalink)
Cheers sweatmachine your help is appreciated.
I shall be ordering those jets.
TinTin
Old 06-30-2007   #4 (permalink)
Favorite Bike: 06 Thruxton(black)
cafecruzin's Avatar
Location: land of sweeping plains,drought n flooding rain
as usual the jenks bolt tuning guide is a very good source
click here
ROD
As is a tale, so is life: not how long it is, but how good it is, is what matters.
Illegitimis nil carborundum
Quot culi, tot sententiae
cafecruzin is offline   Reply With Quote
Old 07-01-2007   #5 (permalink)
Favorite Bike: MINE OF COURSE!
unitedrocker's Avatar
Other Motorcycle: 2005 KTM 450
Extra Motorcycle: Coletta 6'2" pintail
05 Thrux running K&N's and Predators - tried stock 40's with 1 shim, 2.5 turns for the mix (New Bonneville replacements) and 140 mains. Felt hestiation at the crack of the throttle, then pulls hard.
Installed 42's with the rest the same. Seemed to do the same hesitation, building as she heated up. (standard rich issue?) Turned in mix in 1 full turn (1.5) with no better results. Tried 45's and found them building up at idle, way too rich. I'm back to 40's, seems a little better but again with hesitation.
Can't think of anything I'm missing here... thinking about puling the shim, but it sounds like everyone runs fine with them. Suggestions invited.
Never settle for the usual.
'05 865 Thrux-ton - Super-Duper Modified: painted inner tube caps yellow, purple tassels on the bars, and pink neon lighting.
unitedrocker is offline   Reply With Quote
Re-jetting Question? mjc Club Cafe 1 05-28-2007 07:21 PM
One more jetting question - please tri650 Twins Technical Talk 11 02-21-2007 10:30 PM
Oh no, not another jetting question... ivar Twins Talk 6 06-06-2006 02:31 AM
Jetting Question Msullivan Twins Talk 13 03-24-2006 11:01 PM
Jetting Question Stonefly55 Twins Talk 5 02-05-2006 09:50 AM
