BikeBanditSportbikeTrackGearRicor ShocksJardineProducts.comSoupy's PerformanceMotorcycle.comTrident-Exhausts.com
Old 06-27-2007   #1 (permalink)
Favourite Bike: Triumph Thruxton
itcha's Avatar
I am going to swap out the ugly front brake reservoir and I guess I will be needing to bleed the brakes. Having never done it before can you please tell me what is the best way to do this. I have a Haynes service manual but thought I would get some good info from here first.
itcha is offline   Reply With Quote
Old 06-27-2007   #2 (permalink)
If your just switching the reservoir, no bleeding is needed.. Just don't pull the lever when switching, air will only get in the system if the lever is pulled with out the reservoir..
1409 is offline   Reply With Quote
Old 06-28-2007   #3 (permalink)
Whether you bleed now or not, I would recommend a speed bleeder in lieu of the regular bleeder screw. You just take the old bleeder screw out, set it aside, and screw the speed bleeder in with an open ended wrench. Don't use a closed ended wrench or it might be difficult to get off due to the proximity of the banjo fitting. Hold a shop rag under the hole in the caliper where the bleeder fits, as a small amout of brake fluid will probably dribble out.
Once you have the new bleeder fully in place, fit on a piece of clear tubing, the end of which is in an old brake fluid container or something similar. I use an old container with a screw on top. I've drilled a hole the same diameter as the tubing, so everything stays in place. Next is the high tech part. Find an old boot, and stick the drainage container in that. It's very easy for the drainage container to fall over, perhaps pulling the tube out and splattering it all over. So you've got your speed bleeder, your clear tubing that fits nice and tight over the end of the speed bleeder, your draining container holding the end of the tube, and your high tech boot.
You just open the speed bleeder about a quarter turn and start squeezing the brake lever. Refill the reservoir as needed until you've run enough through to be sure that you've purged the old fluid. Don't let the fluid get too low and expose the holes in the bottom of the reservoir. With the speed bleeder, there is no more "squeeze, squeeze, squeeze, open the bleeder, close the bleeder, repeat sixty times." You leave the bleeder open while purging the system. When you've run enough new DOT 4 fluid through, and no more bubbles come out the end of the speed bleeder, close the speed bleeder, squeeze the lever a few times until pressure builds up, and you're good to go. Carefully remove the clear tube, clean the area of any brake fluid, fill the reservoir to the appropriate level and put the gaskets and top back on the reservoir.
Speed Bleeder at NewBonneville.com
2005 T100
Old 06-28-2007   #4 (permalink)
itcha's Avatar
Is the New Bonnie Speed Bleeder a universal bleeder or specific to the Bonnie bikes. Could i get this from any motorcycle accessories place or am I looking for something very specific.
Old 06-28-2007   #5 (permalink)
Favourite Bike: 06 Yellow Thruxton
rbrian_taylor's Avatar
I just replaced my reservoir with the Rizoma. If you use theirs, I highly recommend Teflon tape on the threads of the reservoir. My personal belief is that any time you open a closed hydraulic system, it should be bled. No point in taking a chance, especially on a motorcycle's brakes. I have used speed bleeders on cars without much luck, however, that was 10 years ago.
I am actually interested in those from NB since it is a pain to pump, pump, pump, open the bleeder, close the bleeder, then repeat a good 60 times. In another thread, someone mentioned using a syringe at the bleeder and force the fluid up through the system. Sounds fast and smart, but I don't have any experience with it.
rbrian_taylor is offline   Reply With Quote
Old 06-28-2007   #6 (permalink)
Favourite Bike: 2005 Thruxton (decafe'd)
Other Motorcycle: 1973 Honda CB350K4
Extra Motorcycle: 1987 Yamaha SRX250
Here's my speed bleeder - I asked my wife to pump the brake lever while I opened/closed the valve on the caliper... wives are not nearly as cheap or low maintenance as a speed bleeder. They also protest about sore forearms through the process. A true speed bleeder is soon to be ordered.
I typically leave the top off of the reservoir so that I can add fluid as needed - I end up using a lot of brake fluid to bleed. In actuallity I'm nearly changing the fluid with the amount I add.
Use extreme caution with the brake fluid - it ruins finishes like nothing else out there, save paint stripper. I put shop rags on the tank, fenders and other pretty parts while working. Then I also wash the bike with plenty of soap and water when finished to make doubly sure there are no drips. I had a dissapointing experience with brake fluid and carelessness on a previous bike!
"Well, everybody likes motorcycles... to some degree."
- Bob Dylan
'05 Thruxton, Epco, RaceTech fork springs & cartridge emulators, YSS Shocks, Unifilter, snorkel out, 130 mains, 40 pilot, 1 shim, pilot screw 3 turns, turtle wax
05Truxter is offline   Reply With Quote
Old 06-28-2007   #7 (permalink)
qbit
In a different thread, ( something talking about steering dampers ) I noticed a billet aluminum reservoir, anyone know of a place to order these? @itcha, what are you going to replace your old reservoir with?
Old 06-28-2007   #8 (permalink)
If you first bleed the master, it will then pump fluid much more readily. If you have to pump the master more than a dozen times, you aren't doing it right.
Mecchanica is offline   Reply With Quote
Old 06-28-2007   #9 (permalink)
We covered a lot of this recently.
The Other Brake Bleeding Thread
[ This message was edited by: TBSstunta on 2007-06-28 17:43 ]
2000 TBS Cafe Racer :: 2000 Frankenmille
TBSstunta is offline   Reply With Quote
Old 06-28-2007   #10 (permalink)
itcha's Avatar
Replacing reservoir with this one.
Click here
So does anyones know if you should be able to order the speed bleeder from a motorcyle accessories place or do I need the one specifically from Newbonneville.
Question about bleeding brakes??? Suncoast Sprint Forum 7 11-13-2007 05:42 PM
Bleeding ABS brakes JTXR Sprint Forum 5 06-24-2007 03:05 AM
bleeding brakes abird4 Sprint Forum 7 05-26-2007 09:48 AM
any tips for bleeding brakes? burgessa23 Triumph SuperSports 6 07-29-2005 03:36 PM
Bleeding the Brakes - I need a How-To PassTheGravy Sprint Forum 2 08-08-2004 12:44 AM
Harley Davidson Suzuki GSXR Ducati Forum Kawasaki Forum
V-Rod Forum GSXR Forum Ducati Monster Vulcan Forums
Harley Forum Suzuki SV Honda 600RR Kawasaki ZX Forum
Buell Forum Yamaha R1 Honda 1000RR Kawasaki ZX-10R
KTM Forum Yamaha R6 Honda Fury Forums Triumph Forum
Victory Forums YZF-R6 Forum Honda Goldwing Triumph 675
Can Am Spyder Aprilia Forum Sportbikes Forum BMW S1000RR Forum
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
