Before removing the old pads, crack the bleed nipple with a rag over the end, and rock the caliper side to side to push the piston(s) back into the caliper. A small amount of brake fluid will escape. Then tighten the nipple. Clean the disc surfaces with a scotchbrite and brake cleaner, and wipe with a perfectly clean cotton cloth. Install the new pads....Then continue as recommended.
