i don't want to come across as a schmuck w/my first post, but ..what the hell kind of wrench is used to remove the AI on a 07 thruxton? i've even tried my 13mm flair nut wrench and that didn't fit. will a deep socket fit over that tube?
btw... awesome site, anyone else from CT.
Mike
2007 triumph thruxton
1982 yamaha XJ750 maxim
1969 350 SS camaro
take a chisel or a fairly sharp flathead screwdriver and a hammer. At the base of the metal AI tube, gently but firmly cut it through with the screwdriver and hammer. It sounds crazy but it is very soft metal and wil cut through easily. Then you can get the socket in it. Its how I did it,
I just grabed the tube with a pair of plyers and turn it real gently. It crimped the tube slightly but its usable. If you wanted it in perfect condition you could buy a cheap wrench heat it with a torch and bend it over to fit
On 2007-05-03 18:55, mjsmilford wrote:
i had thought about doing that, but i really wanted to put the parts in a box just in case i needed/had to have them.
You'll soon get over this hangup. It only slows you down. Cut, chop, and move on. It's like cooking without making a mess, you can do it, but its not nearly as fun.
LOL :razz:
06' Thrux
Epco Pea Shooters
Uni Filter W/Bafallectomy
HD Clutch Springs
IKON Progressive Fork Springs/ 7614's out back
Location: land of sweeping plains,drought n flooding rain
use a axe if you have to :hammer: !! get the bloody thing off :-D
ROD
As is a tale, so is life: not how long it is, but how good it is, is what matters. Illegitimis nil carborundum Quot culi, tot sententiae
