The fact that the carb is larger isn't nearly as important as the fact that it's less restrictive
Agreed
Carbs larger than optimum can easily decrease power, and destroy power at lower rpms.
Again I agree, but the hsr's aren't impeding power. That's kinda my point here, these carb's have been tested both on the street as well as on the track. Every bike that has had these carb's installed has seen power gains...not deficit's.
So at what point do you draw the line of larger than optimum?
It seem's absurd to install a 42mm miks on one of our bikes, especially considering hd's are only running one. I know when I got my carb kit they looked kinda freakishly big next to the little cv's they were replacing.
A lot of dyno run's and more info about our bike's with these carb kit's installed can be found
Here
It's the delphi forums incase the link is a mess, seem's to have issues more often than not when posting a link to there. 2001 Modified Triumph Bonnevilles is the specific forum. Bill is a regular there, I'm sure he or other's would be willing to answer any question's you may have regarding the hsr's ability or lack there-of to make power gains.
150+ customers cant all be wrong...
