Let me start off by saying...if you plan on doing the rear fender elimination, and you are thinking about getting the kit to do it, then do it! I must be a complete moron, but I tried to make my own brackets and wire everything myself. I was able to make the hardware, and I soldered all the new turn signal wires, new tail light wires, etc.
Anyway....bottom line is it doesn't work. Tail light works, but no break light, and no turn signals. When I tried the signals, I got this loud buzzing noise from the rear, like a relay or something. I checked all the fuses, they are all good. Now when I try the signals, there are no blinkers or buzzing. Did I blow something? Also...the horn isn't working now either.
Here is how I wired the aftermarket signals and tail light:
front signals: white on bike to white/black on signal, black on bike to black on signal
left rear signal: orange on harness to black/white on signal and black on harness to black on signal
Right rear signal: brown on harness to white/black on signal, black on harness to black on signal
Rear tail light: red on harness to red on tail light, blue on harness to black on tail light, black on harness to ground.
I pretty much copied what that the stock lights looked like. I figured this was easy to do, and it was, and it was especially easy to screw up too.
I checked all my solder connections, they are good and strong and all the solder joints are covered in shrink tube, so no wires are touching.
I'm lost....I should have just bought the kit. Would have been worth it. :???:
Please help if you have any insight on this.
[ This message was edited by: fastforward on 2007-03-20 20:53 ]
