Club Cafe Cafe Racers; the Thruxton and other custom cafe-ed rides.
BikeBandit
Old 03-11-2007   #1 (permalink)
I'm getting some shaking from my thrux front wheel at about 45mph (indicated). Everything is tight and looks right, air pressure is right. Never noticed this before but I haven't been on the bike in a while. Is this common?
devrep is offline   Reply With Quote
Old 03-11-2007   #2 (permalink)
As my front tire wore, this became worse. To the point if I ran hands off it would continue to degrade.
New tire and back to the old smooth ride. I ran the stock tires about 1500 miles too long. For me, the change came at 11,000 miles.
It is not normal or common. I also ran without a front fender for a while, and thought not having the fender support may have allowed some flex in the forks. In my case, it was the worn tire.
[ This message was edited by: whoa on 2007-03-11 11:56 ]
05 Thruxton
whoa is offline   Reply With Quote
Old 03-11-2007   #3 (permalink)
elephant_rider's Avatar
could be the wheel needs to be balanced.
elephant_rider is offline   Reply With Quote
Old 03-12-2007   #4 (permalink)
Favorite Bike: My Bonneville of course
Tire pressure (reckon you checked that) and steering stem bearings being loose can cause this. Just tossing this out there since I have seen this before.
Good luck
04 Bonneville w/904 kit, 1mm over valves, ported, ARK'd, Bub's, HSR 42's, F3 forks, kyb rear shox, F3 clip ons, Brembo M/C, 6 pot caliper, 17" Excel's, this & that
vertwrks is offline   Reply With Quote
Old 03-12-2007   #5 (permalink)
Favorite Bike: Triumph Thruxton 900
jkieler's Avatar
Is your front tire tread cupped, because that will also cause that shake.
Jeremy :hammer: :hammer: :hammer: :hammer: :-D
FAVORITE QUOTE "YOU CAN FIX LOOKS, BUT YOU CAN'T FIX STUPID!"
jkieler is offline   Reply With Quote
Old 07-07-2008   #6 (permalink)
Did you ever solve the problem?
Dangermouse is offline   Reply With Quote
Old 07-07-2008   #7 (permalink)
Favorite Bike: 07 T100
Ski_rat's Avatar
is it the stock tire.
Ski_rat is offline   Reply With Quote
Old 07-07-2008   #8 (permalink)
have you lowered the front (brought the forks up through the triples) or rasied the rear end of the bike?
greytop is offline   Reply With Quote
Old 07-08-2008   #9 (permalink)
Favorite Bike: 06 Thruxton
roxythruxton's Avatar
Other Motorcycle: 76 CB750 86 Yammie SRX-6
Are you still running stock tires ? Those Lasertecs cup easily and IMO pretty crappy . If a rebalance doesn't fix it just buy a new tire .
Get Pirellis . I have the Avon AM26 and developed a high speed " Wobble " in the front with the universal front . Wouldn't recommend them if you ride at high speeds a lot(95mph+). Other than that a decent tire.
Long Live The Limey:D
BIR#220
Yep. I've got some mods .
roxythruxton is offline   Reply With Quote
Front end shake Sprint1050DA Sprint Forum 47 04-28-2008 08:47 AM
Head Shake dna Sprint Forum 2 05-24-2007 05:50 PM
Head Shake Ugarte The Rocket Science Forum 8 10-01-2006 06:17 PM
S4 front end shake Triumph SuperSports 11 06-06-2005 05:45 PM
Sprint RS Front End Shake Sprint Forum 6 05-21-2004 03:46 AM
