"When removing the snorkel"
Remember to throw it as far as you can.
"You don't need anything other than the snorkel bracket to cover the hole correct?"
Correct. But you might want to enlarge the hole in the bracket to be at least as large as the filter entrance.
Did you remove the internal baffle? If not, 120's, if so, 125's should get you close.
