Hi All,
Well, I have some IKON fork springs I want to install on my Thruxton. I've used the search tool and the WIKI, and I feel pretty confident that I could now install fork springs if I had a Bonneville. Problem is I have a Thruxton, and I'm not positive that the installation is the same.
The IKON replacement springs are significantly longer than the stock springs. Does this mean that I ditch the spacer, or do I still need to use it, and if so, do I need to shorten (or lengthen!) it?
The Bonnie folks recommend filling the forks to about 140 or 150 mm from the top of the "stanchion" (the identity of which I am guessing at as the top of the fork tube) before inserting the spring. Is this correct for the Thruxton?
Your help is appreciated.
Mancha
Ogle my bike here.
