Slow leaking rims - front and rear!! - Triumph Forum: Triumph Rat Motorcycle Forums
New BonnevilleHonda Powersports Ontario TourismMotorcycle.com
Old 02-10-2007, 04:18 AM   #1 (permalink)
Healey_100's Avatar
Hello Gentlemen
Just noticed BOTH tyres were quite flat ( Ive only owned the Thruxton now for 6 months) Front tyre was 25lb and the rear 10lb!!
Filled the cold tyres up to 42lb when I noticed water was bubbling from the base of the nozzle and from one of the spokes ( I had just washed the bike).
Our tyres are tubeless, so I assume there are leaks in the seals...?
1. is this a known problem?
2. has anyone fitted tubes or knows of a quick fix
thanks again
WOT! NO BIKE!
Healey_100 is offline   Reply With Quote
Old 02-10-2007, 05:44 AM   #2 (permalink)
1stgarry's Avatar
I thought all Thruxtons had tubes.
And I don't think you can just fit a tubeless tyre to the wheel and expect it to hold pressure.
Are your wheels standard?
'05 Thruxton - black and getting blacker each year
Buell S1 Lightning - as black as it's ever gonna be
Harley XR1200X - very black but not black enough
Buell XB12Ss Lightning - mostly black but with a teeny bit of cherry bomb red translucent
1stgarry is offline   Reply With Quote
Old 02-10-2007, 06:03 AM   #3 (permalink)
Healey_100's Avatar
Ive got stock metzerlers...I though they were tubeless?
Just read on another forum that spoked/wire rimmed bikes fitted with metzerlers ( marked tubeless), they are in fact fitted with inner tubes
true?
still need a fix....
[ This message was edited by: Healey_100 on 2007-02-10 04:19 ]
WOT! NO BIKE!
Old 02-10-2007, 08:23 AM   #4 (permalink)
Favourite Bike: Triumph Thruxton 900
Other Motorcycle: Harley Sportster 1200
Extra Motorcycle: Ducati Sport 1000
The tyres might be tubeless, but on spoked wheels you have to run tubes (unless you have sealed the rims, which isn't standard and generally not recommended).
If'n they be leaking then you gotta pull the wheels and repair/replace the tubes.
Personally, I'd replace the tubes, not repair. They're cheap and you don't want them failing at high speed.
Cheers,
Brett
2005 Harley Sportster 1200
2006 Triumph Thruxton 900
2008 Ducati Sport 1000
bshadbolt is offline   Reply With Quote
Old 02-10-2007, 10:16 AM   #5 (permalink)
Yep, sounds like bad tubes.
2000 TBS Cafe Racer :: 2000 Frankenmille
TBSstunta is offline   Reply With Quote
Old 02-10-2007, 09:03 PM   #6 (permalink)
Just read your post again - 42PSI front and back is a bit too much air.
The recommended pressure is 33PSI front and 38PSI rear.
Either way, the tubes need replacing.
Cheers,
Brett
Old 02-10-2007, 10:48 PM   #7 (permalink)
Favourite Bike: 2003 TBS Orange/Black
jaben's Avatar
I would also remind you that there are "radial" and Bias tubes. You need the RADIAL rated tubes. Just changed my tires and tubes at the end of last season.
John
Sometimes it takes a whole tankful of fuel before you can think straight
My Photo Album
jaben is offline   Reply With Quote
Old 02-10-2007, 11:19 PM   #8 (permalink)
Favourite Bike: Thruxton
Sprint_Dude's Avatar
Other Motorcycle: Thunderbird Sport
When do you need to change tubs? Every year, when you change tiers, or when they leak air? Never had spokes.
If it wern't for the gutter, my mind would be homeless.
BIR#203 "Stumptown"
Sprint_Dude is offline   Reply With Quote
Old 02-11-2007, 02:09 AM   #9 (permalink)
I think my tubes might be leaking. Is it possible to change the tubes with the tire on the rim and not needing a machine to break the bead?
OldSkoolFool is offline   Reply With Quote
Old 02-11-2007, 02:30 AM   #10 (permalink)
The tubes on the stock thruxtons do lose air, but this is normal. They are made of natural rubber which allows air to seep thru the rubber. When you change tires and get new tubes get butyl. They do not lose air as quickly. As pointed out previously there are radial and bias ply tubes. You can break the bead with a vice but you will have to dismount one side of the tire to remove the tube.-T1
have fun-ride often!
thruxtonone is offline   Reply With Quote
Leaking Rear Shock after 400 Miles! ray'striple Street Triple Forum 20 12-17-2007 02:25 AM
Front fork leaking oil...is it hard to fix? Professor_D T3 Sport / Touring Forum 6 08-17-2007 11:23 PM
00 RS Front fork leaking ckassen Maintenance & Workshop Talk 8 07-18-2007 10:19 AM
Leaking front fork BlueBird Twins Technical Talk 4 05-26-2007 07:04 PM
Leaking rear shocks crazypierre Classic, Vintage & Veteran 10 06-14-2005 09:51 AM
