Hagon shock install question - Triumph Forum: Triumph Rat Motorcycle Forums
Old 02-08-2007, 11:34 PM   #1 (permalink)
Hi - I'm in the process of installing a set of Hagon Nitros on my Thruxton, and have everything disassembled. Can anyone tell me if the Hagons are supposed to run with a metal sleeve inside the bushings? They only came with rubber bushings that are a perfect fit for the shock mounting posts, but they don't have the metal sleeve inside like the stock shocks. The stock metal sleeves look way too big for openings in the Hagon bushings.
Also, my Haynes manual has yet to arrive (3 weeks waiting now ) - Can anyone tell me the torque values of the upper and lower shock mounting bolts?
Thanks in advance for any help!
2005 Thruxton; because it keeps me out of trouble.
And some other bikes as well - which don't.
Suburbanrancher is offline   Reply With Quote
Old 02-09-2007, 12:09 AM   #2 (permalink)
Favourite Bike: 04 Bonnie black
No sleeves,bushing on mounting posts is the correct setup. Dab a little grease on the posts to prevent squeaking.
Old 02-09-2007, 02:49 AM   #3 (permalink)
I second Rodburner. Torque 28 Nm. Sorry I'm metricated... A little Locktite won't hurt.
setts is offline   Reply With Quote
Old 02-09-2007, 09:50 AM   #4 (permalink)
Favourite Bike: 750 commando, 750 Bonnie,
Other Motorcycle: BMW R100 RT
A dab of grease (petroleum product) will cause the rubber/synthetic bushings to fall apart. Petroleum products on and belt, hose, motor mounts, suspension bushings is bad news for the for mentioned.
If it squeaks (and you can hear that while riding) use vegetable oil.
Next issue, the lack of shock eye bushing. Call the company and see it there is a bushing. I have installed a lot of shocks, and do not remember any auto shocks with our the bushing.
Steve, Gears and such
:yayyy: :chug: :yayyy:
Uno Para Todos. Todos Para Uno
11B40!!!!
Marilyn, for my husband.
Spyder94 is offline   Reply With Quote
Old 02-09-2007, 05:44 PM   #5 (permalink)
Allright, I installed the shocks without the sleeves like Rodburner and Setts said and everything appears to be fine; I also called the shop today where I bought the shocks and they also confirmed the Hagons do not need the metal sleeve and are designed to go on "as is".
Thanks alot for the help guys!
[ This message was edited by: Suburbanrancher on 2007-02-09 15:45 ]
What Is The Best Way To Install A Hagon Rear Shock? mick-f Sprint Forum 7 12-23-2007 11:00 AM
Hagon 2810 shock install issue? adamoverdrive Twins Technical Talk 13 11-14-2007 02:24 PM
Hagon short shock install TrackerOldGuy Speed Triple Forum 61 11-28-2006 05:54 AM
How much is a Hagon shock for the TB? parrycm Hinckley Classic Triples 11 01-13-2006 11:47 PM
Hagon Shock Bushwhacker Tiger Mods & Bolt-Ons (archive) 6 05-19-2005 07:51 PM
