Fork Oil Recommendations? - Triumph Forum: Triumph Rat Motorcycle Forums
Old 02-07-2007, 11:54 AM   #1 (permalink)
Redoing my front forks this week. Any recommendations on fork oil?
lightning is offline   Reply With Quote
Old 02-07-2007, 03:31 PM   #2 (permalink)
Favourite Bike: '64 Norton N15CS
McQueen's Avatar
Other Motorcycle: '79 Triumph T140D Bonnie
Extra Motorcycle: '71 Triumph T100R Daytona
Which bike?
On both my '79 and '04, I run 20wt fork oil. I have progressives in the '79, stock springs in the '04 (though that will change soon).
In the '79, I had 30wt oil with the progressive springs, but didn't like it. Drained it and went with 20wt.
+ Ton Up Club NorCal +
Nothing says "it's my first day on the Internet!" like putting a picture in your signature.
McQueen is offline   Reply With Quote
Old 02-07-2007, 04:25 PM   #3 (permalink)
on the Thruxton, installing the Works dual rates. Isnt 20 a little thick?
[ This message was edited by: lightning on 2007-02-07 14:28 ]
Old 02-07-2007, 04:32 PM   #4 (permalink)
McQueen's Avatar
20wt works great in my bonnie black.
I guess I'll see when I put progressives in, but I don't think it's too heavy. 30wt is labeled as "heavy duty."
Old 02-09-2007, 05:04 PM   #5 (permalink)
Favourite Bike: 2003 Triumph T100
Sheepdog's Avatar
With the heavier Ikon front springs, my T100 works very responsively with the stock (10wt) fork oil. With the stock springs, I can see why the 20 wt would improve control...the original springs are pretty marginal in the performance department. Apart from my 1960 BMW (that had an Earles front end) and some small-bore Hondas, this is the first bike I've had with 12" long fork springs (the spacers are as long as the springs). The Ikons are full length, progressively wound, and handle big hits much better. For someone who has just bought a Bonnie, or someone with a stock machine, I would suggest that improved fork springs are an essential modification. Do it before any other mod...the stock springs are that bad.
Old 02-09-2007, 10:36 PM   #6 (permalink)
I have a set of Works Dual rates going in. I wound up going with 10 as well once I found out what the stock weight was. Now if someone knows what level of fork oil to put in these things I will be set.
Fork Oil Recommendations Rockfish Classic, Vintage & Veteran 4 08-08-2007 03:46 PM
Bonnie oil recommendations tc_dick Twins Technical Talk 8 07-27-2007 09:59 AM
Oil Recommendations and Oil Filters stmbs Sprint Forum 11 07-20-2006 06:33 PM
Fork oil recommendations BlueTbird Hinckley Classic Triples 4 07-14-2006 06:29 PM
Engine oil recommendations?? please fernman Sprint Forum 31 07-05-2006 05:35 AM
