BellaCorse Air Box Removal Kit - Triumph Forum: Triumph Rat Motorcycle Forums
Old 02-07-2007, 01:18 AM   #1 (permalink)
Favourite Bike: Triumph
Whitehurst's Avatar
Other Motorcycle: R60/5
Extra Motorcycle: r65
Have any of you usedd this kit or have one on your bike?
Just curious on the quality and how it compares to the other ones out there. Looks as though it may have a bit more to offer?
Whitehurst is offline   Reply With Quote
Old 02-07-2007, 01:49 AM   #2 (permalink)
I have it. At the time I bought it, it was aluminum in a world where other kits were steel, and cost was about the same. Mine came with a flat billet/milled carb support rather than the turnbuckle one in the photo, and although the piece is actually cooler than a turnbuckle, it's a little trickier to install, IMHO.
Any of the ARKs seems like a good choice. You'll get more oomph, and a lot more air intake noise. Vroom!
So long, and thanks for all the fish!
DrEnglish is offline   Reply With Quote
Old 02-07-2007, 02:54 AM   #3 (permalink)
Ditto! I have the (N) ARK and am thrilled. Simple carb brace that does the trick perfectly. The induction roar is terrific and when you fire her up you feel the carbs between your legs! Does it for me.
setts is offline   Reply With Quote
Old 02-07-2007, 03:14 PM   #4 (permalink)
I installed the BC kit about 2 months ago. Did a rejet at the same time. The quality of the unit is solid and dropped in with no fuss. Came with the turnbuckle carb support, which works fine, but as others have mentioned, doesn't look quite as good as the milled support brace. For me, it worked fine, and doesn't look that bad. The stuff that hangs on the airbox (Rear brake res., fuse box) all get proper attention on the BC Kit. Everything attaches an secures properly to the unit.
This mod along with my D&D's and a rejet have made the motor come to life. Now on to the suspension...
cheers
-craig
stone is offline   Reply With Quote
Air Box removal Kit from British customs Syynful Twins Technical Talk 10 09-25-2009 09:35 PM
Air-box removal, which kit is better? BlackThrux Club Cafe' 52 02-14-2008 11:29 AM
Thruxton Jetting with BC predetors and air box removal kit listo Twins Technical Talk 23 11-18-2006 12:35 AM
Air box removal kit Motolink Twins Talk 10 06-16-2005 12:39 AM
Which Air Box Removal Kit is Better Surferjo Club Cafe' 15 04-22-2005 05:55 PM
