Nology Ignition Upgrade - Triumph Forum: Triumph Rat Motorcycle Forums
New Bonneville
Old 02-03-2007, 08:46 PM   #1 (permalink)
Anyone out there upgraded their Thrux's ignition system with the Nology coil and wires and iridium plugs?
I already have the coil and plugs installed and have for a while, runs good with them.
Wanna add the wires to the setup, then reading the wire's instructions all kinds of nifty warnings on gaps and timing.
Just wondering if anyone has done a plug and play installation or if afterwards much re-tuning was required.
Thanks!
Ciaooo is offline   Reply With Quote
Nology UK BeastInBlack Twins Technical Talk 8 05-17-2007 06:19 PM
Electronic ignition module for camshaft upgrade? senyorsimon Hinckley Classic Triples 5 12-02-2006 04:28 PM
remove ignition barrel from ignition switch? kanoa Classic, Vintage & Veteran 3 07-13-2006 01:50 PM
Nology Hotwire Ignition wire set Carlsbad_Speedy Twins Talk 12 12-08-2005 12:46 AM
Nology "Thanks!" jimmyj900 Hinckley Classic Triples 9 09-02-2005 12:06 AM
