On 2007-01-29 23:29, steelcap wrote:
I've just ground off the ends of my stock pipes and will start at the internals over the next week or so.
How much did you "gut"? Any tips before I start?
I'm running 150 mains with my TORs and K&N pod filters, so I don't think I'll need to rejet when I try 'em out.
Since you ground off the tip and removed the little tube with packing,you should be looking at the inner cone.
If you have a welding torch you can just cut away the cone to reveal the first baffle.
Then get this baffle out.I just bashed it in to break the tack welds,then used the torch to cut it into small enough pieces to pull out.I left it at this point,but the remaining baffle is the last one,with a tube that looks like an inverted cactus on the other side.You could probably drill or punch addition holes in this baffle to increase the sound,or remove it.I suggest leaving the packing and mesh inner liner in place.It keeps the pipe from sounding tinny.
Your jetting is plenty fat. :-D
