Brice Cooper was the runner up. He is using Ohlins rear shocks and Traxxion AK20 cartridges in the forks. I don't think you will get away with F3 forks on the front. They are using supersport rules for that class
<BR>
<BR>g) Suspension
<BR>
<BR>1) Rear shock(s) may be modified or replaced. All linkage must remain stock. (Suzuki TL models are allowed to use aftermarket linkage to allow for replacing the stock rotary shock with a standard-style shock.) Front fork springs may be modified or replaced.
<BR>
<BR>2) Fork oil may be changed. Fork caps may be changed. Fork internals may be modified or replaced. Fork braces may be modified or added. Triple clamps may be modified only for the purpose of adding a steering damper.
<BR>
<BR>
http://www.ahrma.org/rulebook/sec09.htm
[ This message was edited by: cxc190 on 2007-01-24 19:21 ]
