Motorcycle.com
Club Cafe Cafe Racers; the Thruxton and other custom cafe-ed rides.
Old 11-13-2006   #1 (permalink)
Ok, so i removed the snorkel and it made the bike sound way better. So here is the problem. Now when i'm getting on it around 4k and up it feels like it is falling on it's face. it no longer pulls in the higher rpm's, but rather loses most of it's power. Anyone know why this is? Also i noticed that from the dealer the little hex bolts on the bottom of the carbs one of them is really far out and one is screwed in most of the way. What should i do with them?
caspianthruxton is offline   Reply With Quote
Old 11-13-2006   #2 (permalink)
Favorite Bike: '06 Bonneville Black
Other Motorcycle: '89 FXR
Since removing the snorkel you've made it easier for the bike to breathe...yet nothing has changed for the fuel aspect of the equation. I would rejet...sound's like you need a larger main jet.
As for the screws in the carbs....tighten them.
Hated By All....cause thats just how it is.
SCCTrim is offline   Reply With Quote
Old 11-13-2006   #3 (permalink)
here are some pics. Tighten them down?
[ This message was edited by: caspianthruxton on 2006-11-13 10:42 ]
Old 11-13-2006   #4 (permalink)
Retired Legend
sweatmachine's Avatar
Those are the float bowl drain valves, they should be tight. If they're loose that means the drains are open and fuel could/will be running out of the bowls. Not good.
I'd recommend getting the D-shaped tool from newbonneville and messing with your idle mixture a little, that hole is located near the wires for the carb heaters, kind of centered on the float bowls (bottom of the carbs).
Also, you may need a bigger main and possibly may want to add a shim to your needles.
I'd tighten those float bowl drain screws and add a bigger main, and do the D-screw thing first, then maybe add a shim.
alright alright alright
Bonnie cafefighter!
Old 11-13-2006   #5 (permalink)
If the gold screw's are what you are referring to, they are merely the drain valve's for your float bowls. I have since replaced my keihn's with mikuni's but seem to recall that one did stick out further than the other.
Just make certain they are snug and you'll be fine.
Do you know how your bike is presently jetted?
Old 11-13-2006   #6 (permalink)
it should be jetted to factory spec. I've never touched them and i bought the bike new in august
Old 11-13-2006   #7 (permalink)
Ok, you may want to make a minor adjustment to your idle setting, but you'll probably just need to rejet the bike swapping out the mains for something a bit larger....say 115/118
I wouldnt make a very large adjustment to your idle screw with the d-tool as it's better to be a little lean at idle rather than a little fat.
Old 11-13-2006   #8 (permalink)
sounds good. Also i'm going to be putting some epco stainless mufflers on it this winter. Should i go up some on the jets then as well? If so then i will just put the snorkel on and do both at the same time. Thanks for all the help.
TJ
Old 11-13-2006   #9 (permalink)
When you buy the new pipes I would assume they will come with new jet's for your carbs. Since you'll be removing the snorkel you may need to jet slightly heavier than what they send you.
Best thing to do is get the bike put on a dyno....preferably one close to home and conveniant to you so you can return to the same one when you do future mods for performance comparisons.
Dyno's eliminate guessing games regarding tuning.
Do you have a D-tool?
Old 11-13-2006   #10 (permalink)
do not worry about the float bowl drain bolts. One does stick out more than the other, I'd have to look to remember wich. The bolt just screws in and blocks the port for draining fuel. As long as the screw has hit bottom and there is no gas coming out, you are good. Do not try to tighten them anymore as you may damage them. If I remember right, both bolts are the same size and it is the float bowl that has a different depth hole.
AVMECH is offline   Reply With Quote
AI removed tspapa Twins Technical Talk 5 09-28-2007 09:54 AM
snorkel wildchild Twins Technical Talk 7 04-30-2007 01:06 AM
can this be removed batistuta Speed Triple Forum 6 02-26-2007 07:19 AM
Removed Snorkel! hendog Modifications & Workshop Talk 1 07-30-2006 08:15 PM
Differences with snorkel removed... Liontari Twins Talk 13 12-01-2005 07:44 PM
