Club Cafe Cafe Racers; the Thruxton and other custom cafe-ed rides.
Old 11-05-2006   #1 (permalink)
Thanks to everyone for putting up with my posts about running lean and my cruise surging.
I rebuilt the carbs and reset the floats to 16-17mm according to the Triumph service manual. They were originally closer to 18mm (the outer edge of the published limit).
I ended up with 45 pilots/150 mains, 2.5 turns and 1.5mm of shim on the needle. Going to re-dyno this week.
Two days and about 75 miles on it since the rebuild and it's running great. 130 mph indicated today, no hiccups, hesitation, burps, etc!
Cheers...
'07 SY Tiger
05' Y Thruxton...sold
05' B Thruxton...sold
I hope to open/acquire a Triumph dealership in a few years...
Hozer is offline   Reply With Quote
Old 11-05-2006   #2 (permalink)
Favorite Bike: 750 commando, 750 Bonnie, Guzzi V7 Sport, 850 Le Mans
Other Motorcycle: BMW R100 RT
Coolness of cool!! :lgh: :yayyy: :chug: :yayyy:
Steve,Gears and all things mechanical.
Uno Para Todos. Todos Para Uno
11B40!!!!
Marilyn, for my husband.
Spyder94 is offline   Reply With Quote
Old 11-07-2006   #3 (permalink)
Thank you sir.....excuse my ingornance...but what do you adjust to lower the float bowl and what do you measure off of? THX
PolockJoe is offline   Reply With Quote
Old 11-08-2006   #4 (permalink)
Remove and invert the carbs.
Remove the float chamber cover.
Measure from the gasket surface to the highest point of the float. Triumph specs state 17mm +/- 1mm.
Be sure not to depress the pintle, the float tang should rest on it but not depress the plunger.
(you'll understand when you look at it)
Adjust very carefully by bending the tang of the float.
Let me know if you want the scanned instructions out of the Triumph manual. I'll post them if you'd like.
'07 SY Tiger
The Bike is Fixed. I think. LoVel Biker Hang-Out 10 07-03-2007 02:54 PM
Bike Fixed!!! Jon916996748 Triumph SuperSports 4 04-01-2007 06:59 AM
What, I can't have my tire fixed? Rockster The Rocket Science Forum 14 10-12-2006 09:36 PM
Tach fixed DBR0051 T3 Sport / Touring Forum 3 10-05-2006 10:21 PM
Can this be fixed - cheaply?! ericp Tiger Chat 11 08-20-2005 11:15 PM
