Jason,clamp the bottom eye in a vice,fish TWO straps from TWO of your ratcheting tiedowns around and thru a couple of the coils nearest to the shroud and cinch down the tie downs,alternating sides.Compress the springs a couple inches and the shroud will drop down to expose a 17mm locking nut.Loosen it a bit [I stuck a screw driver thru the upper eye to hold it in place],then unscrew the upper eye from the shaft by hand.Eazy,sleazy. :-D This is what you get afterwards.
