Club Cafe Cafe Racers; the Thruxton and other custom cafe-ed rides.
Old 10-03-2006   #1 (permalink)
i wanted to paint my headlight housing black and i was wondering if anyone has painted their. how did it turn out? any pics? and what did you use?
rabbid is offline   Reply With Quote
Old 10-03-2006   #2 (permalink)
Hmm, if you aren't sure you would like it, I would just wipe the shell with lacquer thinner and rattle can it. Then, if you like the effect, do it right. Strip the chrome electrochemically (battery and battery acid solution.....) and prime with a zinc rich epoxy primer and paint with two part epoxy black. Or have it powdercoated.
Mecchanica is offline   Reply With Quote
Old 10-03-2006   #3 (permalink)
Retired Legend
sweatmachine's Avatar
I sanded mine with fine grit sandpaper then blasted it with rattle can primer, then rattle can glossy black.
Here she be:
I also lowered my headlight by cutting 1.5'' off the bottom of the headlight brackets and welding it on the top, and lowered the gauges using a plate I made. Lots of work.
Old 10-03-2006   #4 (permalink)
Retired Legend
Here's another with my unfinished new rear fender.
Old 10-03-2006   #5 (permalink)
JG
Favorite Bike: 2005 Thruxton
JG's Avatar
Other Motorcycle: 1984 Honda XR350R
I painted my headlight bucket with Dupli-Color Low Gloss Black DE 1634, and the headlight bezel with Dupli-Color Aluminum DE 1615. To prepare the surface, I used a power sander with 100 grit paper to scratch up the bucket and bezel. That sounds coarse, but even with the power sander, it took a lot of time to rough up the surface. The chrome is super tough and was still smooth to the touch when I got done, but you could see the scratches, at least. The only place where I even wore through to the copper plated layer was at the sharper front edge of the bezel. I wiped the pieces down with paint thinner before painting. A day later, the paint withstood my 'finger nail gouge' test, which is as far as I wanted to go with it. Months later and after several encrustings with bugs and several washes, the paint is still fine.
2005 Thruxton
JG is offline   Reply With Quote
Old 10-03-2006   #6 (permalink)
Scuffed housing with scotch brite and painted with VHT gloss black caliper paint. More pictures in my album under thrux mods.-T1
have fun-ride often!
thruxtonone is offline   Reply With Quote
"Idiot lights" ...IN the headlight housing? PaleForce Twins Technical Talk 2 05-01-2007 04:40 PM
Headlight housing short JCRIII Daytona Deliberations 2 08-03-2006 08:34 PM
Headlight brackets - are they painted? Nang Twins Talk 5 10-31-2005 06:08 AM
throttle housing mouse Sprint Forum 0 07-29-2005 10:29 AM
Broken Headlight/Turnsignal Housing Bolt robtroll23 Hinckley Classic Triples 0 06-10-2004 07:17 PM
