Club Cafe Cafe Racers; the Thruxton and other custom cafe-ed rides.
Old 08-15-2006   #1 (permalink)
Healey_100's Avatar
Hi,
Finally got delivery ( purchased unseen over the phone) of my new 2006 Yellow Thruxton today after being shipped 2800 kilometres (1750 miles) by train from Perth, Western Australia to Adelaide, South Australia!! Thats equiv to London to Moscow! anyway.....its still got 4km on the clock.
I have already purchased the Naploeon mirrors to fit on the bike. Im new to bikes ( new after a 20 years absence) and was hoping someone could list a definitive step by step ( ie step 1.....step 2...)on how to fit them in laymans terms.
I know there are several threads on this subject , but it can still be confusing for a newbie like me.
Id be very grateful for any help.
What a great looking bike and I quite like the stock exhaust sound.
healey 100
[ This message was edited by: Healey_100 on 2006-08-15 08:10 ]
WOT! NO BIKE!
Healey_100 is offline   Reply With Quote
Old 08-15-2006   #2 (permalink)
Congrats on the new bike - can't help with the mirrors as I have no idea - but if you don't get an answer here - try posting in the Twin Talk forum where a broader audience exists. There are a number of members sporting these mirrors. Enjoy the new ride. JCW
http://www.triumphrat.net/memberalbums/data/500/thumbs/dragon1.jpg
John W.
  • 04 Thruxton – Graphite & Opal
  • 06 T100 – Black & Red
  • 05 T100 - Black & Opal - Project Bike
  • 51 T100 – Silver & Black
Thrux-ton-up is offline   Reply With Quote
Old 08-15-2006   #3 (permalink)
sfthruxton
I had to customize the mirrors to fit the bike, since the handlebars are solid, with that small bolt... I kind of improvised it, with my buddy's grinder and parts from the hardware store, but here is a step by step link I found for the napoleons. This is for the Tbird, so you'll probably have to improvise a little for the Thruxton, since the bars are solid on the Thrux.
http://www.webbikeworld.com/tbird/mirror/mirrors.htm
Hope this helps.
Old 08-15-2006   #4 (permalink)
mg
I made no mods to the napoleon's... just purchased a longer bolt that has the same thread pattern as stock, trimmed the rubber stopper a bit and tightedned down the mirror. I didn't grind the mirror at all. The result was the mirror sticks out slightly past the grip but otherwise it works nicely. Make sure you have some locktite on the bolt or you might have to check often to make sure the bolt is tight...
mg is offline   Reply With Quote
Old 08-16-2006   #5 (permalink)
Favorite Bike: '01 HD Fat Boy 95ci (blk)
KAH24's Avatar
Other Motorcycle: '06 Speed Triple (black)
Extra Motorcycle: '06 Ninja ZX-10R (green)
If you can return the Napoleons and order the Triumph brand bar end mirrors (Napoleons with adaptors installed); you'd just have a 10 minute installation with no modification needed.
I believe that you have to order the Triumph brand bar end mirrors from a dealership. In the U.S. they list for approx. $105 a pair vs. quite a bit less for the Napoleons that you'd have to mod to fit the solid stock bars.
Karl
KAH24 is offline   Reply With Quote
Old 08-17-2006   #6 (permalink)
Ditto on the Triumph Napoleons, cinch to fit, look good, fitting instructions in the box, shame they are made in Japan
Strangely_Brown is offline   Reply With Quote
Old 08-17-2006   #7 (permalink)
Favorite Bike: 2006 thruxton
Freeze's Avatar
Other Motorcycle: 86 honda vfr 750
Healey,
Not that hard to get them to fit. First take the mirror apart, toss the rubber expansion tube and 8mm bolt. You have to cut off the small protruding piece of metal(rap it in a cloth and place in a vise,as not to scratch it)cut off with a hack saw.replace both the plactic and metal washer/covers buy a 5mm allen head bolt and your done.
Note: left side is easy, right side you have to be care full that you have enough clearance for the brake lever and that the throttle isn't rubbing on the mirror. i have to move both up the bar slightly
hope this helps.
Freeze is offline   Reply With Quote
Old 08-18-2006   #8 (permalink)
Healey_100's Avatar
Gentlemen,
I found this site with intructions to fit the mirrors and will give it a go this weekend.
thanks for all your advice
healey 100
[ This message was edited by: Healey_100 on 2006-08-18 06:42 ]
WOT! NO BIKE!
Old 10-25-2006   #9 (permalink)
Ginseng
Local dealer sugested I tap the end of the bar to fit the 8 1.25 bolts and cut the mirrors.
Seems easy Drill, Tap, Cut, Bolt
On the throtle side I used a washer as a cutting guide so I have about an 1/8 of an inch to keep it from hitting the grip.
Ginseng
[ This message was edited by: Ginseng on 2006-10-26 01:30 ]
Old 10-27-2006   #10 (permalink)
If you look at page 3 maybe 4 on this site at installing napoleon bar end mirrors.The topic was asked by me englishlloyd.I had the same question and followed avmech directions it worked out great.I cut the mirror with a dremel then used a file. Cheers.
ENGLISHLLOYD is offline   Reply With Quote
Napoleon bar end mirror install. orange02ss Club Cafe 3 02-08-2008 07:26 AM
Thrux owner a little confused by forum change BishRat Happenings and Discussions 22 01-28-2008 07:14 PM
new Thrux owner seeks help for aftermarket goodies fastforward Club Cafe 13 02-05-2007 01:56 AM
New 07 thrux owner Tex-ton Club Cafe 18 01-19-2007 07:56 PM
04 S3 Napoleon mirror install 04SpdTrpSE Speed Triple Forum 4 05-01-2004 12:29 AM
