On 2006-05-15 13:36, Thrux-ton-up wrote:
I used RustOlium Enamel that comes in a spray can (he!!, what do you think I am? A professional
Kingmoham - spray bombs are Da Bomb! I've had a number of very nice paint jobs using spray bombs - comes down to preparation. It also helps that you are painting very small areas - compared to say your family sedan. Nice job. JCW
After doing this tank, I can't imagine a much larger sized job without going to professional equipment...cans are good like you said as long as the job is small and the time is put into prep work. The nozzles $uck and if I knew they had others I would have went that route. I should have asked TBSstunta or others, I simply did not think enough to ask. I am not the sharpest knife in the drawer!! I went through lots of old cardboard to get a feel of paint spray, delivery, distance...etc..
Most of all I thought I learned something, and I know it can be done....by myself.
