Mancha,thanks
John,just holding the mini can over the end,changed to tone at idle to a deeper bass.Holding the remnants of the Thrux cans to the end of the mini`s made it almost stock sounding. Having the latitude to use anything or nothing is a good feeling. :-D
Pat,I`ll check out the boltz,but the 12" baffles seem to be doing their job.At low rpm,the pipe isn`t any louder than the stock punched out mufflers.
Thanks King.It looks a bit odd without a pipe or can of some sort,because the pipe sticks out in space.It doesn`t stick out as far as the stockers did but looks odd right now. Also,it comes around the centerstand lugs,so no problem getting to the oil filter or putting it on a lift.
