Club Cafe Cafe Racers; the Thruxton and other custom cafe-ed rides.
Old 04-27-2006   #1 (permalink)
Hi All,
I have a 2005 Thruxton that has an Igniter unit with a part number of T1292365. I have been assured by Triumph Australia that this is the correct part number for my model.
Problem? It hangs off the rev-limiter at 7500 rpm even though this is supposed to be an 8000 rpm unit. (I ran it up to max revs in 3rd gear so that I could see what the tacho was indicating.) Is this the general experience? I would have thought that it would run cleanly to 8000 rpm and then hang off the rev-limiter.
ThruxACT is offline   Reply With Quote
Old 04-27-2006   #2 (permalink)
My Thrux runs clean all the way to 8000rpm AS INDICATED ON THE TACHO. I'd guess either you have the wrong igniter or your tacho is out or there is something else wrong with your engine which is preventing it from getting past 7500rpm.
Most likely your Tacho is out. There's no reason to expect it to be any more accurate than your speedo.
Pete.
Pete.
Do as you will, but harm none.
Pete_Twizz is offline   Reply With Quote
Old 04-27-2006   #3 (permalink)
I would go with Pete_Twizz's theory. May bike doesn't hit the rev limiter until an indicated 8300 on the tach. I have heard as many complaints about the tachs out of whack as the speedos. JCW
http://www.triumphrat.net/memberalbums/data/500/thumbs/dragon1.jpg
John W.
  • 04 Thruxton – Graphite & Opal
  • 06 T100 – Black & Red
  • 05 T100 - Black & Opal - Project Bike
  • 51 T100 – Silver & Black
Thrux-ton-up is offline   Reply With Quote
Old 04-27-2006   #4 (permalink)
Can either be calibrated?
2006 Thruxton
monkeyboy is offline   Reply With Quote
Old 04-30-2006   #5 (permalink)
Favorite Bike: 750 commando, 750 Bonnie, Guzzi V7 Sport, 850 Le Mans
Other Motorcycle: BMW R100 RT
Yes they can. You just have to find a shop (and instrument shop) in your area. Steve.
Uno Para Todos. Todos Para Uno
11B40!!!!
Marilyn, for my husband.
Spyder94 is offline   Reply With Quote
My 07' Thruxton 900 idles to high at 3000 rpm DJ KOOLNESS Club Cafe 7 12-06-2007 03:17 PM
6000 rpm rev limit? Droz T3 Sport / Touring Forum 5 08-03-2007 05:43 PM
Most MPH over the LIMIT?? HiVel Speed Triple Forum 35 02-14-2007 09:54 PM
Procom High Rev Limit Igniter drkside Club Cafe 8 04-25-2006 01:55 PM
What's your limit ??? PA-guy Twins Talk 52 01-14-2006 10:22 AM
