Club Cafe Cafe Racers; the Thruxton and other custom cafe-ed rides.
Old 04-21-2006   #1 (permalink)
Has anyone ever used a different throttle assembly than OEM?
The grip, the plastic sleeve under the grip that graps the two throttle cables, the metal piece that coils the throttle cables up, the brake master cylinder/perch and brake lever are pricey to replace. These are all the pieces I need.
Any suggestions on using an alternative aftermarket setup?
I am also concerned about safety. So this would need to work correctly with the front caliper and be porportioned correctly for stopping power.
Thanks
tokarz33 is offline   Reply With Quote
Old 04-21-2006   #2 (permalink)
Not to pricey! This is for a Thruxton right?
T2040254 grip & throttle tube $9.24
T2040252 throttle actuator $34.17
T2040327 twin throttle cables $29.39
T2026150 brake lever assy $108.40 (every thing)
These prices are 20% over dealer cost! I just bought these parts!
What prices did you get? My dealer is very good to me, let me know if I can help...
Keith..
[ This message was edited by: 04blackbonnie on 2006-04-21 22:05 ]
1409 is offline   Reply With Quote
Old 04-22-2006   #3 (permalink)
Keith,
I don't have all the prices yet but for front brake master cylinder that has a perch was $140. So I am guessing that my other throttle assembly parts would add another easy $100.
T2040254 grip & throttle tube $9.24 -- That sounds cheap. The grip and throttle tube come under one part number?
T2040252 throttle actuator $34.17 -- I am guessing this is the two metal pieces that coil the throttle cables up.
T2040327 twin throttle cables $29.39 -- My cables are fine.
T2026150 brake lever assy $108.40 (every thing) -- What's included with everything? Is this the MC/P with brake lever?
I priced out a complete head light assembly and it was around $350-400. Altenator cover another $140. New tach was $242.
I posted earlier about any suggestions on a Discount parts supplier and no responses so far. 6-7 years ago I ran across a triumph dealer called Wilson or something. Carried triumph, MG, and ducati. I was able to get parts at 15-20% discount. I could not locate the dealer now.
Who's your dealer?
Thanks,
Andrew
Old 04-22-2006   #4 (permalink)
Yes
Yes
T2026150 brake lever assy $108.40 (everything) -- What's included with everything? Is this the MC/P with brake lever?
Yes
T2501262 tach $187.33
T2501261 speedo $174.78
Let me talk to my parts guy to see if he will hook you up.. I'll give him a call!
List is $128.00 List on the tach is $220.39
Keith..
[ This message was edited by: 04blackbonnie on 2006-04-22 00:18 ]
Old 04-23-2006   #5 (permalink)
Any word on your dealer? Which dealer is it?
Old 04-23-2006   #6 (permalink)
You have mail, I sent you a PM!!
Keith..
Need help on clear alternatives install... ThePope Speed Triple Forum 7 01-20-2007 07:14 AM
06 S3 mirror alternatives? buzlin Speed Triple Forum 5 08-24-2005 07:34 AM
What is the valve assembly in front of #1 throttle body? 99TIGER Tiger Workshop 1 06-20-2005 11:58 PM
Scottoil alternatives guydan Tiger Workshop 1 05-29-2005 03:14 AM
Handlebar Alternatives Pig9r Speed Triple Forum 37 05-03-2005 08:41 PM
