Plug hanging between carbs on Thrux - Triumph Forum: Triumph Rat Motorcycle Forums
Ontario TourismNew Bonneville
Old 04-18-2006, 11:25 AM   #1 (permalink)
I was visually scanning my bike yesterday to familiarize myself with the setup and noticed a semi-large two wired connector hanging between my carbs. I figure it's probably something that goes to a different model but was just in the wiring harness since I didn't see anything it would go to but figured I would check with you guys. It traces to the right side side panel (fuse box side) and goes into the bikes harness.
Anyone know what it's for? I would like to remove it but wanted to check before I chop.
Thanks
Stu
'05 Thruxton
Stuie is offline   Reply With Quote
Old 04-18-2006, 12:12 PM   #2 (permalink)
Mancha's Avatar
Maybe you should just tape it up instead of removing it? You should, however, at least tape it up. I think that's the plug that got into my throttle assembly and caused it to occasionally stick.
Ogle my bike here.
Mancha is offline   Reply With Quote
Old 04-18-2006, 12:40 PM   #3 (permalink)
The wiring harness fits a variety of bikes, so is probably a connector not used. I checked one against a wiring diagram and could not find it anywhere. Still, I taped and tucked it out of the way rather than removing.
2005 Thruxton
2000 Speed Triple
whoa is offline   Reply With Quote
Old 04-18-2006, 02:35 PM   #4 (permalink)
Could it be for the accesory socket?
curefan is offline   Reply With Quote
Old 04-19-2006, 11:36 PM   #5 (permalink)
Favourite Bike: 750 commando, 750 Bonnie,
Other Motorcycle: BMW R100 RT
I have been working in the automotive industry for longer than I will admit. It is not uncommon for OEM manufactures to have miscellaneous wiring connectors to be hanging out in the breeze. If it is not in your wiring diagram, tape it shut and hide it away somewhere. Absolutely do not cut it out of the main wiring harness. Leave it alone. This just might be the ADL connector you need to scan the ECM or other electrical issues. Respectively yours, Steve Du Bose, Gear head at large, The Norton's Will Rise Again. Thank you for your time.
Stu
'05 Thrusting
:-D :-D :-D :-D
Uno Para Todos. Todos Para Uno
11B40!!!!
Marilyn, for my husband.
Spyder94 is offline   Reply With Quote
Thrux Carbs- Shims? drock003 Club Cafe' 7 07-16-2007 01:45 PM
Hanging Out Loxpump Twins Talk 9 04-10-2007 06:27 PM
plug between carbs? customcafe Club Cafe' 0 09-03-2006 09:41 PM
Trophy CV carbs at varying altitudes.... EFI vs CV Carbs TiggerTwo Trophy 9 01-17-2006 02:07 AM
plug wrench for thrux/bonnie sid_farkus Maintenance & Workshop Talk 6 05-24-2005 07:46 PM
