Howdy,
2 Progressive Suspension fork spring sets are compatible for use on the Thruxton and available at less cost than the Ikon set
#11-1145, free length 18" (457mm), 40/65 lbs per inch
#11-1122, free length 20" (508mm), 45/70 lbs per inch
These compare to the Ikon progressive fork spring set,
#113, free length 19" (475mm), 46/69 lbs per inch
Cheers.........Agro
"Whale Oil Beef Hooked"
