Turn signals - Triumph Forum: Triumph Rat Motorcycle Forums
Old 04-04-2006, 11:36 PM   #1 (permalink)
Favourite Bike: 06 Sunset Red Sprint ST
Other Motorcycle: 2001 Bonnie
Extra Motorcycle: Daytona675 (#1 wish-list)
I dont much care for the turn signals on the Thruxton. They feel really cheap. I'd like to switch them out for something better (I really dig those used on the new Yamaha 600).
Is there anything I should be aware of before swapping them out? I know very little about wiring and would hate to burn something up (i.e. my bike!).
Thanks!
~Randy DTFR
Ride safe!
RandyDTFR is offline   Reply With Quote
Old 04-05-2006, 12:05 AM   #2 (permalink)
Favourite Bike: 04 Bonnie black
Randy,dang near ANY signals will work if you can make them look good and not just added on. The wiring is the easy part.
Old 04-05-2006, 12:12 AM   #3 (permalink)
It does look pretty straight forward. I noticed in one of the other forums that someone has been having trouble with blown fuses after changing out the signals. Metal housings vs. plastic, grounds etc.
I've been shopping around and came up with a few good ideas, but still got more looking to do.
~Randy DTFR
Ride safe!
Old 04-05-2006, 08:18 AM   #4 (permalink)
Most of the blown fuse issues are probably caused by touching wires together or to the frame while testing the light. Most of the lights [if not all] on the Bonnies have separate power and ground wires because the fenders and headlight/signal unit are rubber mounted and thus isolated from the frame/battery ground. If any of the new lights are single filament bulbs and have two wires,its a plug and play deal. If they only have one wire [ie Kuryakyn Silver Bullet] they have a power wire and ground thru the mounting bolt . This is ideal when the lights are relocated to new brackets mounted directly to the frame.If the lights were mounted to an isolated place like the fender,a separate ground wire might have to be run from the existing wire harness,the battery neg. or to the frame nearby and then hooked to the mounting bolt.All very simple. dual filament lights are just as easy,ground the same etc,they just have two power wires.
Old 04-05-2006, 08:29 AM   #5 (permalink)
yeah blown fuses can be apain!!! if you dont have any lights all of a sudden its prolly a fuse. i learned all day sunday.the hard way..... :hammer:
blue-thrux is offline   Reply With Quote
Old 04-05-2006, 07:11 PM   #6 (permalink)
Blue,did you get them all to work? :???:
Old 04-05-2006, 09:01 PM   #7 (permalink)
yeah everything should be good,just waiting on my rear relocating brackets. i just need to tidy up the harness and get those rears on. thanks for asking. and thanks for the help fellas.
Old 04-09-2006, 11:36 PM   #8 (permalink)
Are you keeping the stock stoplamp, or swapping for something else? I just got around to switching out the turn and stop/tail lamp this weekend. The turn signals are pretty small, I'd like to see how they look. As ugly as the stock are, they do work well.
2005 Thruxton
2000 Speed Triple
whoa is offline   Reply With Quote
Turn signals don't! Anchorbend Twins Technical Talk 9 05-02-2007 10:29 AM
turn signals hardboild Triumph SuperSports 1 09-26-2006 08:43 AM
Turn signals! RocketRay The Rocket Science Forum 2 07-24-2006 08:44 PM
turn signals HardCharger Daytona Deliberations 9 02-07-2005 01:01 PM
Turn signals Trophy 2 08-09-2004 03:02 PM
