I CANT SAY IF THATS AN UNSAFE LEVEL,BUT I THINK THE REASON YOU WOULDNT WANT TOO MUCH OIL IS (sorry caps) because the counter weights on the crankshaft or something like that fling oil up on the cylender walls. if oil level is too high they will churn up a froth ,or air bubles of some kind. if you have air bubles on friction surfaces,then you dont have oil there.air doesnt lubricate nearly as well as oil
not that that helps ya but....
