I have done this procedure with the stock and now the tomaselli's on the bike currently. The throttle has to be repositioned and the cables routed just so and it will work.(not as critical with stock bars as the tomesallis in the high mounted position) On the clutch cable I had to eliminate the stock lower mount and just added a cable tie further up the frame to keep it from contacting the headers. I used a 41mm fork seal to firmly hold the headlight mounts in place and eliminate the need for a spacer. Sorry I can't be more accurate on exact cable location - I just played around with them until they worked. Pics below may help with throttle location on bars. The bars are shown considerably higher than the stock clip-ons and all stock cables work fine.
Wouldn't that actually make them lower? Now that's something I'd consider.
Mancha why don't you cut the tube of the headlight mounts shorter (dropping the headlights and the clip-ons). But if you Really want them low mount the clip-ons underneth the headlight bracket :wink: .
JCW
Thrux-ton-up
this shows the 41mm fork seal (used from the honda F3 lowers when fitted. The grooves in the seal fit perfectly between the headlight mount and fork tube creating a very snug fitment and firmly holding the headlight in place with no spacers. Over 10,000 miles of trouble free use.
Here you can see how the lower cable attachment to the frame was eliminated (and what happens to the cable when it gets to close to the header) the cable tie I added is behind the curve of the header.
