Hey there Steve,
Just got in from the shed. The operation was a success. Well, mostly.
I followed your advice; "When you pick up a wrench, THINK LOVE, and all will be right with things mechanical."
Here is a brief rundown of the operation:
- Covered the tank
- Removed grips (WD40 worked like a charm)
- Removed the controls
- Removed the clocks
- Removed the upper triple clamp (no problems at all...)
- Removed spacers (black CRK spacers where the clipons resided)
- Installed stock clipons
- Installed stock upper triple clamp (with the gentle assistance of a kind mallet)
- Installed clocks
- Tightened everything down
- Installed grips (the hair-spray tip also worked like a charm)
- Installed controls...
...but wait! Ohh, nuts! The kill-switch housing has a split wiring harness that needs to be fed through the front of the fork, not part through the front and the other 'round back! :evil: Then a quick check of the left clutch side... same thing with the light/turn switch housing
Closer inspection of the clutch cable housing shows something upsetting- when Southbay installed the CRK, they removed the lower plastic clutch cable "clamp" to compensate for the higher bars. The cable was resting on the oil cooler which had melted through to the cable itself.
Lucky me I kept all the old parts and was able to put things right again.
Long story short, I have to remove the triple clamp and clipons again, route all the cables around the front, then re-install everything. Still though, I had a great time
Still have to change the brake pads, install Predator exhaust (which are due to arrive in a day or two), and change the oil. Also need a new chain, but have to wait till payday. Might just let the shop do that one though :wink: Don't think I'm ready to remove the wheel and play with the many spacers (many spacers I'm told).
Also have Isle of Man decals also on their way direct from the island itself :-D
Well, time to pack it in for the night. I'll post the photos tomorrow and keep y'all apprised on my progress.
Thanks for all the help! More to come...
~Randy DTFR
Ride safe!
