Not sure the load equalizer will fix it...you may need to be sure that the body of the light is adequately grounded. Some aftermarket signals and taillights complete the curcuit by grounding the light housing...if the housing is insulated from bare metal by nylon washer or similar no current will flow and bingo, no light.
Anyway, it's an alternative hypothesis. Good luck. :-)
So long, and thanks for all the fish!
