efi to carbs... Done! - Page 2 - Triumph Forum: Triumph Rat Motorcycle Forums
SportbikeTrackGear
SportbikeTrackGear
Old 12-26-2012, 07:16 PM   #11 (permalink)
Main Motorcycle: Triumph Tiger 800XC
NORTY FLATZ's Avatar
Other Motorcycle: Harley FXD
Did you dyno your bike before the change? If so, what, where are the increases? Also, did your bike throw any codes?
Reduction in fuel range?
You can't put a price on a good time!
NORTY FLATZ is offline   Reply With Quote
Old 12-27-2012, 04:40 AM   #12 (permalink)
Main Motorcycle: black bonnie
Originally Posted by mikeinva View Post
You used stock carbs and it makes more hp how so?
i'm sorry for my bad english, i mean that the stock 2010 engine make more hp than the 2009, lcd odometer has hc pistons and according to the service manual it make more hp:
790 bonneville 62 hp / 60 nm
865 bonneville carbs 64 hp / 68 nm
865 bonneville efi 66,1 hp / 67,8 nm
865 efi with lcd odo 68,1 hp / 68,4 nm
when i was an injected i have a bad map just because i don't have a dyno near where i live, now with carb the bike run much more better and i noticed a reduction in fuel range
megalo is offline   Reply With Quote
Old 12-27-2012, 04:42 AM   #13 (permalink)
Originally Posted by 1peter View Post
What did the parts cost ?
i've bought everything used, the hardest part to find was the flywheel that i've paid 200 euros
Old 12-27-2012, 06:36 AM   #14 (permalink)
Main Motorcycle: 2000 Triumph Legend TT
Other Motorcycle: 1999 Honda Shadow ACE
well they will if you use stock carbs but not the case if you go to flat slide carbs .Then the carb bike can make more hp then the efi bike that may change sometime but it hasnt yet .
A valid argument, but what if I went with a non-stock EFI system tuned properly? I don't think the non-stock carburetors would have a chance.
You had a bad map? Was this from your own doing?
XeNoMoRpH is offline   Reply With Quote
Old 12-27-2012, 10:21 AM   #15 (permalink)
Main Motorcycle: 03 T100
mikeinva's Avatar
That is the trouble at this time no one has come up with a non-stock efi system that works as good as the non stock carb system for these bikes yet.Some one will in time im sure but it will cost big $$$ and may not make any more hp .The up to date flat slide carbs will be hard to beat at high rpm.
That is where everyone that has tried to build the motors on these bikes with efi has failed to match the carb bikes.I think someone will come up with a efi system that will run with full modded carb motors on these bikes but I think you will have to change most of the system to do so.To make these motors run with big bore /stroker kits you need more air flow then most of the sport bikes have 2 big piston that have to feeed through 2 throttle boddies not 3 or 4 smaller pistons that feed through 3 or 4 throttle bodies.takes alot more air for a 100hp twin then it does for a 100hp triple or 4 banger per bore.triumph did not design the efi systems on these bikes for that kind of air flow they didnt plan on any of us takeing these motors to that high of hp.There system works great on near stock bikes that it was designed to handle.What would one need to get the efi up to do the job?throttle boddies ,injectors ,maybe fuel pump and maybe even a better ecu.That will add up to about 3 times the cost of flat slide carbs maybe $3000 to $4000 add that to the cost of building the motor and things get crazy.
mikeinva is online now   Reply With Quote
Old 12-27-2012, 12:10 PM   #16 (permalink)
Main Motorcycle: 2012 Thruxton
nicholas900's Avatar
Other Motorcycle: 2013 Ducati Diavel
Nice job bro! I love the front facing picture. Looks so nice without the guages sticking up. I want to get rid of my guages and use two small digital guages mounted in a BC top yoke. But it seems hard to do on efi bike.
Don't think I'd go that far myself. But cool none the less.
nicholas900 is offline   Reply With Quote
Old 12-27-2012, 08:29 PM   #17 (permalink)
Main Motorcycle: Thruxton
ThruxOZ's Avatar
Extra Motorcycle: Yz250f
Just wondering could you have just converted your EFI bike to fcr carbies by only fitting carbies. Fitting fuel reg rated at 6psi?
Leaving the EFI ecu to control just the timing?
ThruxOZ is offline   Reply With Quote
Old 12-28-2012, 05:17 AM   #18 (permalink)
Legend
Forchetto's Avatar
I think he's left a few items off his conversion list on post 5, minor details such as a carbed bike's fuel tank (one of the pictures shows a gas tap, not present on an EFI tank), then he would have needed an igniter and the EFI ECU binned. This is because the nature of the ignition signals for EFI are different from the carbed bike, so he couldn't use the original ECU.
Altogether, I can't see all this trouble and expense as worthwhile myself...
So now we have:
Fuel tank
Flywheel
Main wiring harness
Carbs
Ignition coil
Igniter unit
Old 12-28-2012, 07:12 AM   #19 (permalink)
Main Motorcycle: Speedtriple!!
triplestrength's Avatar
Other Motorcycle: Triumph Trophy 900
Extra Motorcycle: Honda CB400AT
Why not buy pre EFI bike and mod that surely more cost effective.
Must be a few low mileage one's out there.
I still struggle to believe that carbs would produce more useful power.
But each to their own.
Sent from my GT-I9100P using Motorcycle.com Free App
triplestrength is online now   Reply With Quote
Old 01-04-2013, 09:23 PM   #20 (permalink)
Originally Posted by triplestrength View Post
Why not buy pre EFI bike ...
I was wondering the same thing.
Marty
Baltobonneville is online now   Reply With Quote
928 carbs blackedout Classic, Vintage & Veteran 1 01-29-2012 07:19 AM
CR carbs vs CVK carbs? jonrem Twins Technical Talk 17 01-03-2012 02:55 PM
Changing monoblocs carbs for concentric carbs bushybester Classic, Vintage & Veteran 9 11-21-2011 02:03 AM
carbs orp Twins Technical Talk 13 03-18-2007 11:48 AM
Trophy CV carbs at varying altitudes.... EFI vs CV Carbs TiggerTwo Trophy 9 01-17-2006 01:07 AM
