2012 Stock Bar End Mirrors Constantly Loosening - Triumph Forum: Triumph Rat Motorcycle Forums
Old 12-06-2012, 08:54 AM   #1 (permalink)
Main Motorcycle: 2012 Thruxton
Have the stock bar end mirrors (which I like) but they cannot seem to be thoroughly tightened. Even when tightening as tight as possible they can still be rotated. pretty easily. Is there a technique for torquing them down properly? Thanks
res0zvle is offline   Reply With Quote
Old 12-06-2012, 09:19 AM   #2 (permalink)
Main Motorcycle: I can't decide!
Hypurone's Avatar
Other Motorcycle: Ducati Monster S4RS
The trick I used when I had them (not very long ) was to remove them and separate the expanding collar portion from the mirror, measure the depth of the part of the mirror that goes into the bar, insert the collar just far enough in so that the bolt will still start and thread properly once the mirror is inserted, insert the mirror and carefully get the bolt started, then tighten as usual.
This made sure the collar was as far in as it could be BEFORE it was expanded by tightening the bolt.
Worked for me YRMV....
Chuck
'10 Thruxton 944cc - In the Faster Color
"Ridin' It Like I Stole It"
Hypurone is offline   Reply With Quote
Old 12-06-2012, 10:04 AM   #3 (permalink)
Other Motorcycle: 2007 Suzuki DL1000
Extra Motorcycle: 2002 KTM 300 EXC
You might try blue loc-tite (the low strength one).
Chewbaca is offline   Reply With Quote
Old 12-06-2012, 11:38 AM   #4 (permalink)
Great, thanks I will give it a shot and report back. Thanks again!
Old 12-06-2012, 12:30 PM   #5 (permalink)
It appears as though the collar is in a fixed position so cannot be fitted deeper inside. It does appear however that the small sleeve that fits inside the mirror (the one the bolt goes through) is a too long so the bolt locks in a loose position. I am thinking of maybe shortening the length of the sleeve.
Old 12-06-2012, 03:32 PM   #6 (permalink)
Main Motorcycle: 2011 Thruxton
Jayell's Avatar
Had the same problem. Here's my solution:
eBay Universal Bar End Mirrors Suzuki Honda Yamaha Kawasaki Aprilia Ducati BMW Black
Jayell is offline   Reply With Quote
Old 12-06-2012, 03:34 PM   #7 (permalink)
Couldnt ever get them to hold in place either?
Old 12-07-2012, 07:47 AM   #8 (permalink)
Finally figured out what the problem was. When the dealer put the bike together they inserted the sleeves for the bolt inside the mirrors (as opposed to inserting them through the outside end of the mirror.
Old 12-07-2012, 11:40 AM   #9 (permalink)
Hypurone's Avatar
DOH!
Chuck
Old 12-07-2012, 07:38 PM   #10 (permalink)
Jayell's Avatar
Mine held tight for two years, then one began to act up. I didn't take a close look at a fix because I had already decided to replace them.
Glad you found the answer for yours.
mirrors 2012 Thruxton rmw Club Cafe' 26 06-27-2012 04:29 AM
Link for the homemade bar end mirrors from stock mirrors? cf04thruxton Club Cafe' 13 06-17-2008 09:04 AM
Loosening the Chain zighawk Twins Talk 16 10-07-2005 05:50 AM
