2012 Stock Bar End Mirrors Constantly Loosening - Page 2 - Triumph Forum: Triumph Rat Motorcycle Forums
Old 12-08-2012, 08:21 PM   #11 (permalink)
Main Motorcycle: 2012 Thruxton
ANSAracingb's Avatar
Originally Posted by res0zvle View Post
Finally figured out what the problem was. When the dealer put the bike together they inserted the sleeves for the bolt inside the mirrors (as opposed to inserting them through the outside end of the mirror.
This happened on my bike, but only on the left side. I tried to torque the bolt down but was afraid I'd strip it. When I took the bike in for its 500 mile service I had them fix the mirror (the bike is under warranty and its not MY fault it came off the showroom with a loose mirror). The tech explained to me that they fixed it pretty much they same way you posted, above.
I want to get the small bar end style mirrors but for now the stock ones are o.k.
-Bryan
2012 Triumph Thruxton 900
ANSAracingb is offline   Reply With Quote
Old 12-09-2012, 05:52 PM   #12 (permalink)
Main Motorcycle: 2011 Thruxton
Jayell's Avatar
I had no clue what this meant until I pulled mine out of a box and took a look.
Mine had the sleeves on the inside as well. I suspect this is the proper way it should be done. However, should they become loose, shortening the sleeves by as little as 1/8" or perhaps even less and leaving them inside, would accomplish the same as placing them on the outside.
Jayell is offline   Reply With Quote
Old 12-10-2012, 08:17 AM   #13 (permalink)
My first though (as I stated above) was to shorten the sleeve. After thinking about it, I concluded that Triumph probably didn't manufacture sleeves that were too long. More likely the sleeve is supposed to slide through the outside of the mirror.
res0zvle is offline   Reply With Quote
Old 12-10-2012, 03:22 PM   #14 (permalink)
700
Main Motorcycle: 2013 Black Thruxton
700's Avatar
Hello, don't mean to jack this thread. I have the opposite. How do you remove those stock mirrors on a 2013 Thrux. Is there more to it than just removing the screws. All I have left are the chrome bar-ends. Do I twist these off somewhere? They are very hard to turn.
700 is offline   Reply With Quote
Old 12-10-2012, 03:29 PM   #15 (permalink)
Jayell's Avatar
Twist and pull should do; no special tricks or tools.
Old 12-10-2012, 03:56 PM   #16 (permalink)
Jayell's Avatar
Hehe...so you did. I ought to pay closer attention. Glad it worked out for you.
Old 12-13-2012, 10:25 AM   #17 (permalink)
Newbie
Main Motorcycle: Rocket III
I simply added a few semi-soft washers that I purchased from Home Depot.
JFowler176 is offline   Reply With Quote
Old 12-13-2012, 06:58 PM   #18 (permalink)
Thats a good solution. It would be nice to know the actual technique for installing the mirrors (either outside the mirror or otherwise).
Old 12-14-2012, 06:07 PM   #19 (permalink)
Newbie
Main Motorcycle: Legend & T120
Other Motorcycle: Triumph Legend
Extra Motorcycle: Triumph T120 1970
Rotating mirrors
Have the stock bar end mirrors (which I like) but they cannot seem to be thoroughly tightened. Even when tightening as tight as possible they can still be rotated. pretty easily. Is there a technique for torquing them down properly? Thanks
It could well be that the wedge piece that fits into the bar is locking out before a full grip is obtained due to the gauge of the bar being thinner than ideal for the wedge ie the internal diameter is greater than the best suited size. Try wrapping some shim material around the wedge with the wedge just on the point of contact, before insertion into the bar then tighten up ( a strip cut from a beer can could work)
triplet is offline   Reply With Quote
mirrors 2012 Thruxton rmw Club Cafe' 26 06-27-2012 04:29 AM
Link for the homemade bar end mirrors from stock mirrors? cf04thruxton Club Cafe' 13 06-17-2008 09:04 AM
Loosening the Chain zighawk Twins Talk 16 10-07-2005 05:50 AM
