Need HELP on TPUSA C arb Powerpack Install
I've been installing the TPUSA carb powerpack upgrade on my '07 Thruxton today. Ran into two issues that have me stuck. The first is a sensor that was plugged into the RH side of the airbox that I can't figure ou what it was plugged into (can't find a plug on the bike). I think it's a temp sensor (bottom picture). Do I need it? The second is something I think goes with the SAIS. I've removed all of it and installed the cylinder head plugs, but what's this thing? The hose coming out of the back of it plugs into a black plastic T-pipe that connects the two carbs, so I'm not sure I should remove that, but it seems like it's useless since I reomoved everything else associated with the SAIS. Thanks--this a great forum! Hopefully the pictures post OK below.
'07 Thruxton: Rox Speed 2" risers, 130w/90w headlight w/ relay, OEM tank pads, OEM fly screen, TPUSA carb powerpack special, Hagon nitro shocks, Progressive fork springs, "old style" fork gaitors, Napoleon mirrors, screw-in oil temp guage
