Dominator Carb Rejet - Triumph Forum: Triumph Rat Motorcycle Forums
Club Cafe' Cafe Racers; the Thruxton, Bobber and other custom cafe styled bikes.
post #1 of 8 (permalink) Old 11-08-2012, 01:51 PM Thread Starter
Main Motorcycle: 2007 Triumph Thruxton
kjax909's Avatar
Other Motorcycle: 2002 BMW R1150R
Bit the bullet and ordered the TPUSA Dominator Carb Power Pack special (touring pipe option) for my'07 Thruxton. For those that have actually installed this upgrade, how spot on is TPUSA's choice of replacement jets (I'm not even sure what size they are sending)? Will I likely be experimenting with several combos? For what it's worth, I'm about 600' above sea level.
'07 Thruxton: Rox Speed 2" risers, 130w/90w headlight w/ relay, OEM tank pads, OEM fly screen, TPUSA carb powerpack special, Hagon nitro shocks, Progressive fork springs, "old style" fork gaitors, Napoleon mirrors, screw-in oil temp guage
kjax909 is offline
post #2 of 8 (permalink) Old 11-08-2012, 05:32 PM
Main Motorcycle: 2008 Bonneville Black
perfectbonnie's Avatar
kjax,
I don't remember the details, but I took the recommendations of Carlos at TPUSA for my DT's on my '08 Bonnie with snorkel removed and AI disabled, and they were right on.
perfectbonnie is offline
post #3 of 8 (permalink) Old 11-08-2012, 11:17 PM
Main Motorcycle: 06 Thruxton
Other Motorcycle: 05 Thruxton
Extra Motorcycle: 06 sporty 1200
Send a message via AIM to TJRCARRILLO
Most likely the jets they send you will be spot on. You will probably have to adjust your mixture screw.
Sent from my iPhone using MO Free
TJRCARRILLO is offline
post #4 of 8 (permalink) Old 11-09-2012, 02:15 PM
Main Motorcycle: '07 Bonneville T100
zenbike's Avatar
Other Motorcycle: '01 Sprint RS (Sold it)
Not sure what jets they sent you, but on a related note I bought the performance package from BC and they sent me 135 and 140 mains and 42 pilots. I installed the 42 pilots and the 140 mains. Took it into the dealer to check the A/F as I don't have all the proper tools, he said it was spot on with the A/F gauge measurements. All they did was sync the carbs and adjust the mixture screw.
I've got a 2007 T100, so different needles I think, but very similar.
zenbike is online now
post #5 of 8 (permalink) Old 11-09-2012, 02:45 PM
Main Motorcycle: 2014 Scrambler
bluesforchallah's Avatar
If you find that the jetting TPUSA sends you is not adequate, the link below will give you some valuable information about setting/tuning your carbs. I'd start with 42 pilot jets and experiment with the main jets.
Myself, I'm running BC Predators with 150 on the main jet and trying to sort out other issues on the lower end of the RPM range so Iíve been going back and forth between 42 and 45 pilots. You can't really go by what others have set up. Fact of the matter is, no two bikes are the same. That's what makes it challenging to tune these bikes. You can have two of the same bikes sitting side by side with the same mods but require different settings of jets and air mixture. It would be nice to be able to jet the bike the same as a buddy and expect to achieve the same results. Unfortunately, that isn't going to happen. There are just too many variables.
http://www.duncanracing.com/TechCent...arbJetting.pdf
Chris / RudeBoy BIR #309
2014 Scrambler: Arrow 2-1 high pipe. TTP Tune 4 with Breathe airbox cover no baffle.
Past rides:2008 T100, 1975 Honda CB400/4, 1989 Honda GB500, 1965 Honda CB450 Black Bomber, 1972 BSA A75 Rocket3
bluesforchallah is offline
post #6 of 8 (permalink) Old 11-09-2012, 08:03 PM Thread Starter
kjax909's Avatar
Thanks
Thanms for the info. I'll have to install what they send and if don't experience noticeable problems, I'll procedd to having it dyno'd. Fortunately we have one local.
kjax909 is offline
post #7 of 8 (permalink) Old 11-14-2012, 11:00 AM
Main Motorcycle: 08 Bonneville T100 C/S
wenzel850's Avatar
I have the same kit on my 08 T100, and live about 500 ft above sea level,the jets Carlos sent me where right on.
Ride safe,
Quentin
wenzel850 is online now
post #8 of 8 (permalink) Old 11-18-2012, 01:58 PM Thread Starter
kjax909's Avatar
All worked well
Got the kit installed over the last two days. I haven't adjusted the air fuel mixture or synced the carbs and the bike runs great. It seems spot on to me, but I'll have to get on a dyno with an EGA. And the sound, the sound--it's the stuff dreams are made of. I can't stop thinking about it.
kjax909 is offline
How to rejet a carb - should I go to the dealer? PTwin Cruisers - America, Speedmaster 24 07-31-2012 11:40 PM
07 America carb Rejet? dba6463 The Welcome Center 1 03-22-2012 04:33 PM
Anyone Use a Carb Balancer After a Rejet? Huffer Air Cooled Twins Technical Talk 32 09-12-2008 04:17 PM
Carb rejet ?? TroyH Club Cafe' 3 03-31-2007 05:49 PM
